Question about Refrigerators
PSS26PSTASS WIRING DIAGRAM "RUBBER HEATER" WIRE PULLED OUT OF HARNESS ON HIGH VOLTAGE SIDE OF PC BOARD THIS IS NOT A COPPER WIRE IT HAS A COILED WIRE IN RUBBER "LIKE A FILL TUBE HEATER WOULD HAVE" IT GRAY WITH A BLUR TRACER...IF I REMEMBER CORRECTLY. ops not yelling ..cap lock was on...LOL
    Top Expert:
  • Refrigerators Master
  • 10,875 Answers
    Top Expert:
  • 44,366 Answers
Google that it was too small to hardly see!! but here is one they want paid for GE Profile Side by Side Refrigerator PSS26PSTASS Service Manual in PDF...
Posted on Apr 27, 2015
Power winow wiring diagram for 2004 venture
https://s2.postimg.org/einm75w6x/power_windows.jpg
Click on the link.
Check the wire harness on hinge side of driver door. Probably has a protective rubber boot, see if you can pull boot back far enough to get at yellow wire, key on, use a test lite and probe yellow wire, see if there is voltage.
At the lower part of diagram, see black wire, terminal G, that is ground, find that in wire harness and check it. You can use a test lite connected to battery voltage, probe the black wire, if the lite comes on, at least the ground is good enough to turn on the test lite. Because you open and close the driver door so much, sometimes those wires break.
When probing any wires, cover the hole with fingernail polish or something, when your done.
Jul 21, 2017 | 2004 Chevrolet Venture Passanger
Windows stop working. swtich fuse and relay are good.
I'd probably check the wiring harness on hinge side of driver door. There is probably a protective rubber boot covering, pull the boot back to see wire colors. Look at wiring diagram for your power windows, check the proper wire colors for voltage and ground.
If you want me to try to post wiring diagram, I need year--make--model?
Your owners manual may show you which fuse and/or relay controls the power windows.
Nov 09, 2016 | Cars & Trucks
Which fuse control drivers side power window on a 2003 Chevy tahoe
It's a circuit breaker. The voltage to the circuit breaker is hot all the time, so check for voltage at the circuit breaker. Use a test lite or something.
See the orange wire, check the wiring harness on hinge side of driver door, the wire harness will have a protective rubber boot covering of some kind, pull the boot back far enough to check the orange wire for voltage. If it has voltage, the problem may be inside the door?
Sep 25, 2016 | 2003 Chevrolet Tahoe
2005 Chevy Equinox Power Seat Switch Diagram!
You see the circuit breaker, supplies voltage to power seat switch, You see the wire color? On hinge side of driver door is probably a wiring harness, probably has a protective rubber boot covering. Pull the boot back far enough to see wire colors, use a testlight, have to penetrate the insulation to get at the wiring. If no voltage, either wire is broken or check for voltage at the circuit breaker. Black wire is ground, check that also.
You see the wire colors for seat motors, those are voltage and ground, depending on which way the motor is moving.
Jun 05, 2016 | 2005 Chevrolet Equinox
Where are power switch for window control 03 Aztec
I would check the wiring harness going into the driver side door, on the hinge side. The wire harness probably has a protective rubber boot covering, see if you can move cover back so you can see wire colors. The yellow wire is voltage for power window master switch. Black wire is ground. The wire harness is flexed every time the driver door is opened or closed.
I looked at info for Pontiac aztek.
Nov 25, 2015 | Cars & Trucks
My passenger windows won't let down but my driverside controls work fine.
What is year--make--model? You may have a wiring harness on hinge side of passenger door. Probably has a protective rubber boot covering, Pull the rubber boot back so you can access the proper wire color for voltage and ground. I can't look up the proper wiring diagram w/o knowing which vehicle you have?
May 12, 2015 | Cars & Trucks
CODES P0031 AND P0051 A/F RATIO HEATER CIRCUIT low have no batt voltage at sensors can't find any blown fuses any idea 04 toyota sequoia
You will need wiring diagrams, to find components
and diagnose the problem
You have 2 O2 Sensor Codes-- for Heater issues
I would look for an O2 Relay, for the heaters, once
you have a diagram to work with
Battery voltage will be to the heaters only
Don't put your meter on the black sensor
wire, you may ruin the sensor, by loading the circuit
Just work the 2 white heater wires on chassis
side, for the 12 v
Unplug the O2 Sensors, and probe the harness heater
wires only, until you get your 12v back
Feb 23, 2011 | 2004 Toyota Sequoia
We have a Jenn air jed8430. It was installed but never supplied power to it or tested. We want to make sure the wires are right before powering it up. Black is with Black. Red is with Black with Red...
I just looked, and there is not a wiring diagram available on the web for this unit.
I am concerned about the black with red stripe to red.
Check to see if there is a wiring diagram somewhere on the unit (there wasn't one in the installation instruction or manual for this unit.). I believe the red wire on the house side goes to the black/black wire on the cooktop side (so I believe you are correct on your concern.).
House side green should be to the coiled silver cooktop side silver wire.
But the wiring diagram will confirm these things.
I think the black/red stripe is for the blower.
Jan 28, 2009 | Jenn-Air JED8430 Electric Cooktop
Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Dec 16, 2008 | Dayton (3E379) Heater
FREEZER PROBLEMS
Max, you have a defrost problem and it's probably the heater. To make sure, access the main board on the back side of the refrigerator. On the board you will see a blue 3 pronged harness on the lower left side. Take a jumper wire with clips and jump line to defrost. Keep the harness on but give yourself enough room to clip on. This will send 120 V to the heater itself. The heater is on the bottom side of the coils. One side should have a blue wire and the other side a pink. If the heater does not come on, verify that you have 120 V by checking the voltage on the blue and pink wires. If you have that voltage and no heat, replace the heater. If you don't have the voltage, replace the board. Catriver.
Nov 10, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
