How do I reset error P98-6 on a Riso EZ201? - Office Equipment & Supplies
Riso RP3700 gives A17221 error msg
have you checked you master disposal unit if there were any masters jammed in it?
Jan 29, 2014 | Riso RP 3700
My riso ks 800 duplicator shows E13 Error code
my riso ks 800 duplicator show error code E3
Apr 14, 2011 | Office Equipment & Supplies
ERROR CODE T04-513 FOR RISO RP 3790
riso rp 3790 no imprime, no copia, me dijeron que borrara errores pero no se donde, creen que sea eso
Feb 27, 2010 | Riso Office Equipment & Supplies
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
Feb 13, 2010 | Sharp AL 1631 Copier
My riso s-8000 has error code to1-594. how can I get passed this code.
This basically means that the drum in position 2 is in a locked state. Try to rotate it manually, then reset the machine by holding down the reset key during power on.
Aug 20, 2009 | Riso RZ220 Duplicator
Code Error T4
T-4 is an ink overflow condition. You may need to check and clean out ink section of drum. Remove the ink then press reset button. Then turn off and on and re-insert ink.
Dec 01, 2008 | Riso RZ220 Duplicator
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Error Code T14 on Riso GR3770
The machine is not alinged. I had that code this evening and the guy came here and in no time he fixed it. is your drum going in the machine? if so then turn off the machine and while pushing down the clear/reset button turn the machine on
Oct 16, 2008 | Riso RZ220 Duplicator
51 people viewed this question
jasbo
jasbo
