Question about Refrigerators
Hi, I need to know what MODEL of florescent bulb goes in to the unit? The original broke and I cant find it in the manual
    Top Expert:
  • Refrigerators Master
  • 10,875 Answers
Http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/CFG48_spm.pdf
there is no listing for the 40,but there is a 48,same thing,
CRG-24/36/48/74 LAMP (FLO) 40W GE10471 is the bulb,but,you can also find it in the manual i just gave you
Posted on Apr 27, 2015
The nipple from my primer bulb that goes into the gas tank has fallen into the tank. I got it out but I cannot reattach it to the hole it came out of.
didnt specify unit --generic answer--if primer broke will need to replace the unit or if held down by screws then just bulb needs replacement
May 10, 2017 | Garden
The dimmer switch will turn on and off but wont dim the lights on a chandelier. model 6681-w. tried 2 different ones with the same results.
The Leviton 6681 is a push-button rotary-type incandescent dimmer with 600Watt capacity
If you have incandescent bulbs, the dimmer should work.
If the dimmer has different color wires, try reversing the wires.
If the dimmer replaced a 3-way switch, then this is not the right dimmer.
If you have compact florescent bulbs, you need a dimmer that also dims florescent.
http://www.google.com/products/catalog
Link shows the Leviton 6673 incandescent and florescent dimmer
But you also need dimmable compact florescent bulbs.
http://www.amazon.com/DIMMABLE-COMPACT-FLUORESCENT-LIGHT-SPIRAL/dp/B0014B84ZM
Oct 31, 2010 | Leviton #L11-06681-00I Ivory 600 Watt Push...
Hi my display does not come on
If you don't see the Alpine logo while booting up then the florescent bulb for the LCD must be burnt.
Apr 25, 2010 | Alpine CVA-1003 Car Video Player
How can I take out the side florescent bulbs encased in plastic?
Usually the plastic tube has two end caps that hold the plastic tube onto the lamp. These end caps allow the connection pins to go through a slot in the end of the cap.
If the lighting fitting is the turn type then turn the complete tube and over tube by the end caps and remove the tube/over tube. If it is in a lighting fitting where you just push the connection back and pull the pins out of the fitting.
The end caps will have a ridge that the plastic tube fitts into at each end.
I have seen some overtubes have screw on end caps.
Regards
Alan Hood
ami-man
UK
Aug 10, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 CD 50 disk - florescent bulbs change
You have to rotate the tube 90 degrees until you hear a click, then it pulls straight out of the sockets at the top and bottom (towards you). In order to grip the tube Wurlitzer put a black plastic cap on the end of the tubes with a bit sticking out for you to get hold of. On models where the colour cylinder is flexable you can actually squeeze it in the middle and grab the tube that way.
Dave.
Nov 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Light does not come on when I open/close door, not the bulb
Good Morning:
I also substituted Floescent Bulbs for the standard bulbs. The bulbs would not light up although the relay was working. It seemed that the Florescent bulbs had a somewhat shorter neck. What I did was unplug the drive system from the outlet and then bend the metal connector in the socket so that it would come out further towards the opening of the socket. I then repluged the drive. The Floercent bulbs now have contact and are working perfectly. Simple problem with a simple solution.
Sandman
Oct 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
KitchenAid wall mounted stainless steel stove hood (model KWCU285HSS) The florescent bulb stopped working. A new bulb didn't work any better. When I tried to install a new starter I noticed that the...
Hi ahev you took the unti off the wall as you need to do this to be able to acess the internal electrics of the unit.
Did you fit it on the wall or get somebody else to do it.
Their is three screws holding it to wall one either side and one up towards the top let me know if you understand what im going on about
Jan 29, 2008 | KitchenAid KWCU205HSS Kitchen Hood
Hood lights constantly zapping out.
I have a similar unit - KitchenAid wall mounted stainless steel stove hood (model KWCU285HSS). Please let me know if you figure out how to open the thing/canopy up. I'm trying to get into the area above the florescent light & starter.
Spencer
Jan 16, 2008 | KitchenAid KWCU360J Kitchen Hood
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
