Question about Pool & Spa
How do I prime this well water pump?? It's a sta-rite pump!!
    Top Expert:
  • Pool & Spa Master
  • 5,045 Answers
Put water in basket open inlet close top and turn on
Posted on Apr 20, 2016
  • 19 Answers
SOURCE: water comes out of the backflush when in filter mode.
bad gasket on diverter valve
Posted on May 01, 2009
  • 59 Answers
SOURCE: Spa Motor Hums
if it is a used pump, these have a tendency to have a little rust. just get some pump pliers and rock the shaft gently back and forth. then plug it back in.
David
Posted on May 25, 2009
  • 3600 Answers
SOURCE: Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Posted on Sep 29, 2009
tweedleedee0
  • 15 Answers
SOURCE: I have a sta rite pool filtere and it is running
Pump motors used in most pool aplications can not be reversed. Changing the wires on the capacitor or reversing the line connections will not change the motor rotation. A failed capacitor can, from time to time, let a motor start "backwards" but it will not happen often if even at all. You might need to take the motor to a local electric2_bing.gif motor repair shop for an inspection.
Posted on Jun 27, 2010
  • 366 Answers
SOURCE: How do you replace a seal on a Sta-Rite pool pump?
Replacing a shaft seal requires some good mechanical ability.
first, always make sure power is off at the breaker before you work.
You'll have to remove the band holding the wet end to the seal plate. Then remove the diffuser covering the impeller. Remove the cover on the back of the motor. You either need a 7/16 open end wrench or a armature tool to hold the motor shaft while you unthread the impeller (if the impeller has a screw in the middle, you will have to remove it by turning clockwise, left hand threads) counterclockwise. You can then pull the carbon part of the seal off of the impeller, make sure to remove all of it including the metal sleeve. You will then have to remove the seal plate and push the ceramic part out from the back. You can then clean and lube the seal plate and install the new ceramic part of the seal, try not to touch the ceramic with your hands if possible. You can then lightly lube the impeller shaft and slide the carbon part of the seal with the carbon facing toward the ceramic as you thread it on. If the seal plate had a copper heat sink, you can either replace it or use a different size seal. (I believe it's a PS-201) Re-install the seal plate, impeller (and screw if applicable) and diffuser. You should now be ready to mate the seal plate to the wet end. Make sure you fill the pump before you try starting it up, especially with a new (dry) seal.
Posted on Aug 16, 2010
Testimonial: "Very helpful thank you for your time."
Where to add water to prime pump ds3hf-01 sta rite
water is filled in the body of the pump to prime it
fill the filter housing if that is part of the pump
make sure that there is no open pipes /hoses or air leaks on the suction side of the pump and that includes any vacuum machine hoses floating on the water surface
Jun 26, 2016 | Sta Rite Pool & Spa
How to prime sta rite pool filters
put water in pump basket and turn on after opening valve 1 at a time
Nov 03, 2013 | Sta Rite StaRite DuraGlas Pump 34 HP...
Have deep well vetical sta rite pump both pipes in ground staying full of water will not pump press does not looose prime but wont build press
shut off pump breaker at the lowest faucet drain completely. Turn it back on. If this doesn't work, you have to change out the pressure valve on the side of the tank. it's not hard.
Oct 08, 2012 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Prime the pump
see the FIRST in red under the STA-RITEremove the lid fill the pump up with about 3 gallons of water then replace the lid and start the pump. should start to flow in about 1 minute, if not repeat priming procedure
Jul 19, 2012 | Sta Rite Industries Shallow Well Jet...
Do u have to prime all pumps
YES all pool pumps need to be primed, failure to do so will destroy the shaft seal AND could cause serious damage to the pump and motor. starving pumps is bad also. Make sure they have water, it makes them happy.
Apr 28, 2012 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do we hook up this pump up to our pool
HORISONTAL LINE IS THE SUCTION LINE.(SKIMMER AND DRAIN) ..THE ONE THAT COMES OUT THE TOP IS THE DISCHARGE LINE, THIS ONE GOES TO THE FILTER. USE SILICONE ON THE FITTINGS THREADS, THREAD TAPE CAN END UP CRACKING THE PUMP. THIS STA RITE IS THE BEST PUMP!!!.. PRIME PUMP WITH WATER AFTER ANY PUMP REPAIR !!
Jun 02, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Do I need gasket sealer on gasket between motor and pump housing on sta-rite water pump?
You will know if the housing has a gasket groove cut in it for a o-ring. if not no gasket needed.
The Pool Tech
Jul 10, 2010 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
2 hp vertical sta-rite well pump
Did you prime the pump? To prime: Before turning pump on, unscrew plug cap from top of pump (usually on pump impeller housing,) and with a pitcher or garden hose, fill pump full of water, and replace plug. Then turn pump on and see if problem is solved. If leaking: Are all fittings tight, O-rings and seals new, and is there any pipe thread tape on all threads w/o seals?
Nov 02, 2008 | Sta Rite STA-RITE IMPELLER 2HP FULLRATE &...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
