Question about Health & Beauty
Not working I open it in side power pcb some component burn can I get new pcb for that
2 Suggested Answers
SOURCE: Burned component in Sony Vaio laptop.
MY LAPTOP LOCKED UP ON ME
Posted on Apr 08, 2010
No turning of motor in my Kenwood MX270 Patissier
Follow the power, start looking wherever the power stops. Sometimes it can help to reverse phase & neutral to track where the power stops from the other side too. You are only doing this for testing purposes and need to put it back as it should be when you're done.
Dec 08, 2014 | Kenwood MX270 Patissier Food Processor
The light comes on that it is full but will not turn on power. This dehumidifier is not new but did work last winter and is fairly new.
check the main PCB board if has burn connection check fuses if ok if not replace new one on pcb board connect with wire the burn out connection or replace new one.check the resistance of motor & compressor if good using ommeter.
Jan 28, 2011 | Fedders Dehumidifiers
Freecom Classic SL hard drive stopped working
Probable reason for failure of a disk is power, if the power is adequate may be some of its components like inductor, diodes in series with the power line are opened, check for any burn marks on the pcb
Jul 14, 2010 | Freecom Classic (22095) (22095)...
Model HSB03 stopped working after power outage. Is still like new would like to keep ....any suggestions?
HI. What generally happens during a power outage, will be a serious surge. The surge will, essentially, destroy the Main PCB. Without proper PCB function, the unit will not operate. All power is controlled by the main PCB. It routes power to the compressor and fans, as well. You can, visibly, inspect the affected part by pulling the access panel on the rear side of the unit. It will be mounted on a bracket, near the compressor assembly, or just in the middle section of the rear side of your unit. Inspect the Circuits and relays that are mounted on the PCB. If burn marks are present, or a brownish discoloration is sited on the circuit board, simply replace the PCB.
NOTE_ PCB location may vary in your model Generally, they are located just behind a access panel, on the rear side of the unit. Some may be mounted in close proximity of the compressor platform.
Jan 14, 2010 | Haier Refrigerators
Not working on sound, but fine with channel
Try cleaning the side of the pcb where the rubber buttons rest on with a q tip soaked with acetone. You can also use methylated spirit. If this does not work, then there is probably an open circuit in the pcb or a component is not functioning. You need a multimeter and some knowlegde of electronics to test the components.
Aug 17, 2009 | Bose Televison & Video
Hp 2605n Fuser error 50.7
50.7 means that the photo sensor ps6 detected no movement
Open the side of the printer power on the printer and check if the fuser motor moves forward and back. If it does the problem is with the movement sensor or feedback circuitry. If it doesn't its the motor, gear system jamming, motor driver or power supply pcb.
Aug 11, 2009 | HP Color LaserJet 2600n Printer
Power supply problems
Have ordered a new power supply PCB as too many parts need replacement. Best to buy the whole lot.
Ventilation seems to be an issue with this unit, I am thinking of installing a small fan at the back to cool the voltage regulator and main transformer.
Thanks.
Jul 07, 2009 | Televison & Video
Health & Beauty Logo
297 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
