Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
I replaced the control board and still comes up F06 Bad control board. I am looking for the wiring connections for the board.
Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
I have a whirlpool duet steam and reads codes F06 E 02 and replaced the electric controller and now reads F06 E01
OK your almost there. The switch or Latch that locks the door is faulty or bad. It is either that or probably not connected to the right terminal. New control board!!! That was expensive! Good luck!
Jan 16, 2014 | Washing Machines
Front load whirlpool reads codes f06 e02 tech told me it was the pump just need to know what u guys think?
Unfortunately F06 E02 is a very bad error. It means you have an interface communication error. That means that the main control board isn't communicating with the front interface control board. You can pull the washer out and remove the 3 screws coming in from the back of the top panel. Next, the top panel will pull straight back, up, and off. Now check all the wire connections between the two control board and make sure they are all secure. If everything looks good, then the interface control board will need to be ordered and replaced.
THIS IS WHAT I HAVE FOUND OUT FOR YOU ON SEVERAL FORUMS ON THE INTERNET BUT IT WOULD BE EASIER TO RING AN EXPERT BUT I HAVE FOUND OUT IT WILL COST ABOUT 150 TO FIX
Dec 29, 2013 | Washing Machines
Whirlpool duet washer-error F06 and E02
Here is a link to the part.
Oct 19, 2012 | Whirlpool Duet Steam WFW9750WR Washer
F06 error code
F6 error indicate a Motor Speed error code. It is likely attributed to either a broken or slipped drive belt, defective Drive Motor, defective Motor Control Unit (MCU), or the interconnecting wiring between the two.
Could be a loose connection in the harnesses, dad Motor, bad motor control board, bad main control board. It's most likely a bad motor control board.
Here is the one parts for your model:
- Electronic control assembly
- Motor Control Unit
- Drive Motor
Also, remember that RepairClinic.com will refund all parts within 30 days that you purchase from them if they don't fix the problem, EVEN electronic parts.
Hope this helps.
Sep 22, 2011 | Kenmore HE2 Plus Front Load Washer
What does F06 mean?
F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
A failed drive motor.
A defective motor control board.
A failed main machine control board.
Hope thie helps (remember to rate and comment this answer)
Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
My kenmore is showing an f 06 code
F06 is a communication error between the central control circuit board and the motor control circuit board, Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU, check your owners manual, some are covered under warranty for up to 5 yrs.
Jun 19, 2010 | Kenmore Elite 45986 Front Load Washer
Code flashing F 06 wont spin
The code F06:Drive motor tachometer error happens when the control unit is unable to properly detect motor speed.
If you are planning on doing this yourself then in order to troubleshoot this you will need to remove the back panel to gain access to the motor and wiring harness.
Check the motor by turning the pulley. If the motor does not turn smoothly then it's most likely a bad motor. If this seems ok inspect the wiring harness for any broken or loose connections. It's a good idea to unplug and then reinsert all the connections between the board and motor. This helps clean any corrosion that may have built up on them.
If your still having problems then the MCU (motor control board) may need to be replaced.
I hope this helps.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400L4
f06 is an error pertaining to the motor control board loacated behind the lower acess panel mounted in the left fron corner, first check for loose wire connection, sometimes alot of water/moisture will trip the control, remove and refit the wire harness leading to the control a few times and look for physiacal damage to board as well.
Nov 10, 2008 | Whirlpool GHW9400 Front Load Washer
F06 error code on Whirlpool duet washer
I have the whirlpool Duet 9150 with the same issue. I removed, reseated and reconnected every connector at least 4 times with the same random result of F06 to the point where it no longer finished the load. I then removed the motor control board again and sprayed it down with electronic cleaner along with all connections by disconnecting them , spraying them down and then reconnect and connected a few times to ensure good contact. I then tried again and the F -06 code came back. I then ordered the board for $ 150 online . When the new board arrived 4 days later, my wife tried the washer one more time and it worked. I have performed over 2 dozen loads . The board was never replaced. It appeared that spraying the board and connectors worked.
Nov 08, 2008 | Whirlpool GHW9400 Duet Washer
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
64 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
