Question about Magnavox Televison & Video
I need a fuse for 42" magnavox plasma tv T8AH250VP
  • Lois A Delawder
    Lois A Delawder Apr 28, 2015
    Greatly appreciated your help and I have ordered the fuses. Thank You
    Top Expert:
  • Magnavox Master
  • 48,486 Answers
Check the fuse store .
Posted on Apr 27, 2015
42" magnavox plasma tv lost
The power supply feed deferent voltages to the TV and the Problem is the electrolytic caps need change out on the power supply module, or you can go to www.partstor.com and get a new one.
Aug 30, 2011 | Televison & Video
My magnavox 42'' TV ,plasma wont turn on when i push the on button it just makes a few clicking noises at different points then shuts off. i get nothing on the screen. what had happened was i accidentally...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 06, 2017 | Philips Magnavox 42MF521D/37 Television
I purchased a phillips magnavox tv in 2006
Just google the model # and you should come up with it.
Nov 17, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Magnavox 42"
You are correct=====Return it ! It's new, you should not have to have it repaired this soon.
Sep 23, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
There is no picture but have audio
Your mainboard is damaged and need to be replaced. in order to get a new one you will need a product code and model number, both located in the back of th TV next to serial number.
Jun 03, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
My Magnavox 42" plasma TV purchased from Home Depot also went out last night.....No picture only audio. What a shame! looking for a posible solution
power supply board - check the fuses first --- remove all cords and power cord -- wait one day then connect -- if this doesnt work -- you probably need a new power supply board without looking at it - can order online at partstore.com
Feb 27, 2009 | Philips Magnavox 42MF521D/37 Television
42" magnavox plasma started to smoke, has audio but no video?
power board replacement a burnt circuit is visible upon opening unit and removing the power board.
Jan 27, 2009 | Televison & Video
My dead 42" plasma - power problem
I went to Radio Shack and bought a 4 pack of 6.3amp 250v glass fuses (5x20)...stuck one in and it works like a charm.
Anyone know of any problem using a 6.3amp fuse instead of an 8amp one? I am thinking it just would blow out sooner...and I have 3 more I can go through until I find an 8amp fuse...am I crazy?
Jun 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Open Questions:
Magnavox MWR-20V6 DVD/VCR recorder fails to record one time but not the next This problem just recently started as the unit was functioning perfectly up to now. And I've kept the unit in excellent condition and free of any dust. What's happening is this. When the timer is set to record a program, the unit will turn on and begin to record. But after about 9-10 seconds of recording, it will fail and you'll see an error message saying you cannot record on this disk. FYI, this happens too when not using the timer and just pressing record. And in both cases, it's been hit or miss, so one time it successfully records no problem and the next time no. So you don't know when and if it's going to happen, which is really frustrating! What's even weirder is that once it failed, you can wait a few seconds and try recording again with possible success. So if it failed at first, it may work the next time, but who knows if it'll work after this. And even if it does work the next time, after that, it's again hit or miss. This recording problem happens even when dubbing. So it doesn't matter if you're copying from VHS to DVD, using the time, or just hitting DVD record, the same recording error happens. And as I said above, it may work the next time but who knows? And even if it worked then, anytime after that is also very hit or miss. Nobody else touches the unit and it's never been moved or banged. So again, I've kept it in very good shape and working order. No problems whatsoever on the VCR side. And I most often use DVD-R discs rather than RWs, but even with RWs, the same problem can happen. Lastly, finalizing has also become more hit or miss now when it used to be very consistent. So I don't even know when or if it'll be successful in finalizing a discs. Most times, it does work, but a couple of times, it hasn't. Lastly, a weird thing with discs that failed to finalize is this. A few of them were finally able to be successfully finalized after just sitting around for about a month of not being able to be finalized. So for whatever reason, a few of those discs that wouldn't repeatedly finalize suddenly worked. The rest of those that were not successful still cannot be finalized. And I've kept all these discs in plastic sleeves or in a disc case.
Jan 17, 2018 | Magnavox Televison & Video
Televison & Video Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
