Question about Generic Sony Mobile Xperia Sp C5306 Smartphone - Wi-fi - 4g - Bar - Black 1271-4775 -
The screen was locked on a game loading and nothing can be moved.
Playing high level candy crush out 2/10/16 tried to buy extra moves to beat level game froze and went back to home screen.Now game takes long time trying to load, fails and goes back to my home screen
I'm certainly not a gamer, but in this case try restarting the iPhone.
If that doesn't help remove the app and do a fresh re-install from the app store. In-App purchases can be restored. I'm not sure if you retain your game status - again i'm not a gamer.
Sep 01, 2017 | Apple iPad Tablets & eReaders
Unlock
The Lock symbol needs to moved to the right to the unlock symbol by your finger.
This will then load the desktop and activate the touch screen.
Support Troubleshooting Guide
Apr 18, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
When i load portal 2 on ps3 the screens flickers and a moving yellow triangle with a red exclamation mark appears and the game does not work. I have exchanged disks and it still does not work. All other...
I think I found the problem. I started getting this problem after I moved to uk. If you shutdown you ps3 then unplug the network cable. Start your ps3 while the cable is still unplug. You'll be able to play the game once again. Steam sucks they region lock the game via steam I'm guessing. You cannot play portal 2 US version while being in UK.
Aug 15, 2011 | Video Game Consoles & Games
Bowrowed assassin's creed 2 from my mate, get through first sequence to where your in the animus 2.0 for the first time. I am in the white loading room to continue and nothing happens. I am stuck as...
That is the loading screen. If it doesn't finish loading the disc could be scratched, or the system could be overheating.
Clean the disk, then try again.
If failure continues move the PS3 to a more ventilated location, and try to remove the dust from the vents.
Mar 17, 2011 | Ubi Soft Assassins Creed: Brotherhood
Slimline PS2 has started to only read some games, not others
Hello. Base on you're problem description, and from my own experience, I believe the problem is with your lens. I recommend that you take a closer look in to it. Take it to your local game store and have it cleaned.
Jun 16, 2009 | Sony PlayStation 2 Slimline Console
Fifa 09 (PC) not loading background
Unistall the game and reisntall it.if ur system meet system requriments then this problem will solve
Jun 13, 2009 | Video Game Consoles & Games
Console wont load games or blu ray dvds
Your game read lazer is probably busted you have to send it in to the playstation service with a receipt and they will fix it for you.
Feb 21, 2009 | Sony Playstation 3 (PS3) Console
Frigidaire LTF2940ES Hums
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Memory Card- Loading a black screen
You Might Have A Bad Memory Card. Also Try It on A diffrent System.
May 25, 2007 | Sony PlayStation 2 (PS2) Console
Generic Sony Mobile Xperia Sp C5306 Smartphone - Wi-fi - 4g - Bar - Black 1271-4775 - Logo
89 people viewed this question
Top Generic Cameras Experts
ka4iup
ka4iup
Jay Plesset
Tony Parsons
Tony Parsons
Are you a Generic Camera Expert? Answer questions, earn points and help others
