Question about Electrical Supplies
Garbage disposal is operating with the switch either ON or OFF.
  • 2,210 Answers
Bad switch. Replace
Posted on May 04, 2015
    Top Expert:
  • Electrical S... Master
  • 45,340 Answers
You better get an electrician
Posted on Apr 28, 2015
They don't work garbage want my money back
Robert,
Garbage disposals are not designed to take ALL of your garbage... and DO NOT use one if you are on a septic system!!
If it is not working, check for voltage to the switch, from the switch to the disposal,,if you have voltage to the disposal, some have a reset on the disposal..
Jul 05, 2017 | Garbage Disposals
Garbage disposal wont run, power is on. Reset button pushed, not jammed.
Here's a video AKLILEABRAHA suggested as a solution to your problem from YouTube:
Fix Your Own Garbage Disposal | Disposal Repair | No Cost | Save $$$
May 05, 2013 | Waste King L-3300 Legend Series 3/4 HP...
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Copy following link to repair, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
Garbage disposal
My checklist for garbage disposals:
(1) most disposals have a little red RESET switch on the bottom. Once the impeller will turn manually, press the reset button, and you may get back full operation.
(2) 120 Volt wall switch may have burned out. They're only rated for 100,000 operations before they burn out.
(3) If the impeller is difficult to turn, you may try to use an "flywheel wrench", which is just an offset Allen wrench that fits into the bottom of the motor, and can be used to turn the flywheel manually, freeing the impeller and allowing the reset to work.
(4) The circuit breaker in the breaker panel in the basement may have tripped, cutting power to the switch controlling the garbage disposal. If tripped, turn off the switch to the disposal and reset the breaker.
(5) Disposal motor may have died.
This How-To seems like a nice one:
http://homerepair.about.com/od/plumbingrepair/ss/fix_disposal.htm
Nov 26, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Our garbage disposal won't turn off. batch feed
Turn off circuit breaker, and replace switch
Sep 03, 2011 | KitchenAid Batch Feed Garbage Disposal...
The garbage disposal hums but won't work. What could it be?
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Apr 09, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal won't turn on. Appears to be clogged
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
a
Sep 25, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal does not have an electric on off switch it is turned on and off by inserting the drain stopper and removing it, I have removed the drain stopper but the in sinkerator continues to run.
The switch is bad that the stopper hits to activate the disposal...
heatman101
Aug 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger insinkerator 1(1/3 HP) is humming but not operating
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Aug 07, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage Disposal. Operates but water does not empty and shoots up into sink.
Took the trap off and emptied debre in it . Works fine now. Thanks for checking. Ed Bachleda
Oct 05, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Electrical Supplies Logo
298 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
