Question about Husqvarna Garden
How to replace belt on 48in cut mower deck - Husqvarna Garden
    Top Expert:
  • Husqvarna Master
  • 10,875 Answers
Posted on Apr 27, 2015
2006 p0lan mower deck belt routing 48in.
Request belt installation instructions directly from Poulan.
Jun 19, 2017 | Garden
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
How do you replace drive belt on a 19 hp yardman 46 cut
Lisa, You could try to Google search your make and model# manual.
Check the attached links manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
46 Deck Belt Pulley Routing Riding Mower
Replace Your Lawn Tractor Deck Belt
MTD YARD MACHINES 46 CUT RIDING MOWER DECK BELT INSTALLATION REPLACEMENT
Yard Man 604 Operator Manual
Aug 06, 2016 | Garden
I have a 2016 x350 with a 48in accu deck and it's cutting uneven and I'll readjust it and it seems to go back to cutting uneven
Many people overlook the very first thing which must be checked for an uneven cut:-- proper inflation of tires. It's got to be either that or perhaps a slightly bent blade - or both. Otherwise, you've got something going on with your deck leveling process. I carry a small level with my mower and DR brush mower so I know I get accurate oil checks and also so I can place them in a dead level position to check oil and tire presure. Start at the bottom and work your way up. One more thing: you could have a very slow leak. If you haven't done so, get some slime and put in all your tires on all your lawn equipment. Amazing stuff.
May 20, 2016 | Garden
I got a a craftsman DLT 2000 riding mower 48in
look it up on sears.com to get the part number & size
Sep 24, 2014 | Garden
Cutting deck on my rancher ride on will not
ON some mower decks the pullies have small metal tabs/keepers that are supposed to prevent the belts from flying off when disengaged. I have replaced my belt before and went around the keepers rather than behind. this will add tension and will shread the belt. You might look and see if the belt is indeed on the pullies correctly and not around one of the pully tabs, I hope this helps.
Oct 28, 2009 | Garden
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
How do you change the deck belt of a 48in 21 hp husquvarna tractor
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532426477.pdf
Go to the above link and you can download a very good manual for it. It shows the routing of the belts as well as a lot of other useful information
Sep 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
53 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
