Question about Shoprider Health & Beauty
I have a faulty ca-ac2-70 main controller. Does anyone know where I can get a wiring diagram so I can test it to fix the problem? The same for a rhino and s drive controller. Thankyou
    Top Expert:
  • 10,875 Answers
Treadmill blowing electrics when switched on
Step 1:
1) please use desk lamp and connect in outlet wall, where the treadmill is connected.
2) if the breaker or fuse is blown, the problem is the outlet wall.
3) Test the wire ground with DVOM, if there are touching with another wires inside of the outlet
4) test the another wires white + black, if there are touching, or there connecting with the carcase from the outlet and repair.
Step 2:
1) if the problem if the machine: please test the power cord use the DVOM for continuity
see the video for measure continuity
2) test the main switch from treadmill
3) test the reset switch for continuity
4) test the fuse +c.breaker for faulty with contunuity and repair
5) test the power supply continuit see the block diagram
Step 3:
please test the main motor for open or faulty see my personal TIPS for motor help.
2) test the output main board , for input voltage motor, if there are NOT the board is faulty,replace the boaatd use the DVOM for measure Voltage.
use the diagram above mentioned.
Jan 07, 2013 | Exercise & Fitness
How do i fix my treadmill
RUN the software calibration for diagnose, troubleshooting and fix it.
adjust the reed switch see diagram +adjust the speed sensor clean and tight the wires connector very well.
2) test the drive belt motor, 3) LUBE THE deck belt,+4) Lube the rollers bearing 5) test the motor +main board control for faulty. see the diagram attached.
God bless you
Jul 19, 2012 | Exercise & Fitness
Nordic track treadmill trips breaker
1) I am assuming that the breaker is the treadmill and Not from your house.
2)you must test the Main Motor. measure the voltage without load
3)now you must test the main motor controller board.
4) transformer.test .see the block diagram and see how the main motor board has aprox 90% of functions of any treadmill.
12_14_2011_4_11_07_pm.gifGood luck. Sincerely. G-d bless you
ERNESTO CUADRAMANAGUA, NICARAGUA C.A
Dec 14, 2011 | NordicTrack Treadmill
Epic 425 Mx Treadmill EPTL88105 buttons dont work
1) Try to open the top consol.
2) Spray with contact cleaner( from radio schack or computer store)
3) Tight the flexible cable from keypanel vs display board
4) Tight the connector from display board to Lower board( Main Controller Board)
5) Test the main controller board.
6) Test the transformer.
Finally See the Block diagram that I did, you will see how the Main Controller Board has the 90% in any control. In that way you will have a good Strenght resultante, for to determine who is faulty. sincerely. Good luck.
11_28_2011_5_16_12_pm.gifE.CUADRA
MANAGUA, NICARAGUA. C.A
Nov 27, 2011 | Epic 425 Mx Treadmill EPTL88105 !
Nautilus t714 error code L5. Can you tell me what this error code means? Thank you. Tim
Dear Sir:
I just want to say to L5 means many things.
1)You must check socket wiring from upper board(display) vs lower board(controller motor board)
2)Short circuit in capacitor(EMI) in input circuit or Short circuit in Main Motor Test.
3)Faulty Controller Motor Board-Replace.
4)Realign Sensor Speed Motor and clean or Replace
Since the Controller Motor Board control 90% function in Treadmill , will the most probably cause, after you did Test all Step before mentioned. And strong concluded the Lower Board is Faulty.
sincerely.
If you need further assistance, please reach me.
E.CUADRA
MANAGUA,NICARAGUA. C.A.
Nov 22, 2011 | Exercise & Fitness
Fitnex t60 display says prg bad, what does that mean and how can i repair it
1) You must test first the power supply for +5DC for I.Circuit( Including EPROM, ROM, etc)
2) Test the flexible cable between KeyPanel and display board, and clean.
3) Chechk the connector between Display Board with the lower board(Main Controller Motor)for loose connection, loose wire.
4) Test the transformer controller supplying the 12VCA, to the power supply at the Main Controller Board since this supply the +5vd to the Display Board.
Finally you must have Strong Conclusion if the problem is 1)Display Board faulty, 2) Power supply Faulty, 3) Transformer Controller Faulty 4) Main Controller Board Faulty.
For All test you must use Dvoltmeter.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA.C.A
Nov 21, 2011 | Fitnex T60 Light Commercial Treadmill
Please can anyone help me I bought a 560hr treadmill today second hand it was workin perfectly, until my son and grandson went on it ..it now will turn on but the belt will not go it trips the power switch...
12_7_2011_9_56_59_pm.gifSee the block diagram that I did for you. Now you will see how many elements or component has the treadmills. If the fuse or breaker are trips. you must inspect and test: 1) Power cord some internal wires is touching insider and produce short-circuit. 2)Capacitor in short 3) Coil or transformer in short 4) Main Motor in short 5) Main Controller Board.
Finally see for any wire is loose and touch the chassis from the machine in that case produce a BIG SHORT. sincerely.
Good luck, G-d bless you.
E.CUADRA
Apr 03, 2011 | Proform 560hr Treadmill Walking Belt
Reverse Light blinks on and off while driving
look under the air cleaner box for loose reverse wire on switch. 1 wire with green and white wire. loose, its grounded not in reverse and opens when put in reverse. hope it helps
Aug 20, 2009 | Little Tikes Yamaha Rhino 660 Ride on Car
Electric Diagram for Kenmore Model 790
Has the oven run out of control or gotten too hot? The 790 series is made by Frigidaire and those fault codes are F0 to F8. F2 indicates the temperature sensor is reading too hot. Now with the double oven models, some manufactures add an extra digit to the fault codes to indicate which oven created the fault.
Your most likely fix is to replace the temperature sensor. The most probable locations for the wiring diagram is taped inside the bottom drawer, on the back or under side of the oven, or behind one of the panels on the back of the oven. This might tell you the room temperature resistance for the temperature sensor so you can test it with an ohmmeter and be sure that it is faulty. Try Appliance Parts Pros for replacement sensors.
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Health & Beauty Logo
209 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
