Question about LG Televison & Video
How do I get the picture back on my LG LED 50 flat screen? Sound works, no picture.
The screen went dark on our year and a half old LG LED 50 flat screen. Sound works, can see screen when you shine a flash light on it. Replaced the power supply/LED board on it and it didn't fix it. Model # 50LN5100. Service code: 50LN5100-UB.BUSYLJR, what part should I replace now?
  • 47 Answers
-You have a bad panel. Led arrays internal to the panel are defective. Replacement cost exceeds economical repair.
Posted on Jul 10, 2015
  • 11800 Answers
SOURCE: lg flat screen model 26lx1d
The blinking red light signals the fact that the power source is in protected mode - it's fully functional (as the green light also shows) but has been shut down by it protection system.
The protection system of the source is engaged when 2 things happen: either there's a short on one of it outputs (you will have to test the output voltages to identify the failing board and from there if the board can be repaired - start with the inverter) or if the processor can't load the firmware - this is almost always caused by a hardware failure of the processor and in that case the mainboard will have to be replaced.
In that case it will cost you around $200 to get a replacement board, plus the labor. Now you must decide if the tv is worth that amount of money - in my opinion it doesn't.
Posted on Sep 27, 2010
SOURCE: No picture on mu LG television.
Try the old flashlight test, turn off the lights in the room. Turn on the set and flash a bright flashlight on the screen. Do you see the image or is the screen totally black?? If you see the image, then most likely you have a backlight problem. Verify that you have 24V on the power supply for the inverter
Posted on May 21, 2012
  • 2432 Answers
SOURCE: lg philips main board, ive just replaced this board as old board was stuck in service mode flashing red blue green screen, ive connected this new board an now have sound but no picture. t-con board te
does the screen totally black or with only white screen?. recheck all the connections going to t-con board and x board which you missed.
Posted on Oct 03, 2012
  • 75032 Answers
SOURCE: lg led tv backlight
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Feb 05, 2015
  • 75032 Answers
SOURCE: Technovision 3251 32 flat screen television with phillips pt190 pt3 power supply whitch has being replaced with known good board after switch on still nothing no standby light backlight sound
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Feb 06, 2015
Testimonial: "My thoughts to as I was looking in the way of known stock faults with this board helpfull on theConformation.7"
My TV has sound but screen is dark
Go into menu settings of tv and look to see if the energy saving box is ticked.this is usually designed to run by selection of user not by default from may even have an intelligent saver which can detect if the screen is using a lot of power when the image is predominantly white as opposed to black so it turns the brightness down.too clever for its own good!
Nov 16, 2015 | Toshiba 50 Class 1080p 120Hz LED Smart HD...
I have no light on my led tv
The most likely problem is the Backlight Inverter. It supplies the power to the LED array which illuminates the screen. If you are brave and also technically able, it can be replaced at home. Here is a video to help. LCD TV Repair Tutorial How to Replace the Backlight Inverter Board in LG...
Oct 27, 2015 | LG 50" 5400 Series LED HDTV - 50LN5400
Screen went dark but can see picture in dark room with flashlight
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 19, 2015 | LG 50LN5600 50" LED TV 1920x1080, 60 Hz,...
Lg model 47ln5750 screen went black
That model is an LED Backlit unit. The LED driver could be bad or there could be a power supply problem. Sometimes the problem is a cable connection. Is there an picture that you can see in a dark room? If you can see a faint picture, the problem is probably the LED back light.
May 18, 2015 | LG 47LN5700 47" LED TV 1920x1080, 120 Hz,...
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
My LG 42pc1DV has sound normal but picture just died and is blacl, before this happened I had a lot of green pixels that only showed up across screen on dark pictures, 4 year old and just out of warrenty
Either your Y sustain board went out or your upper and lower Y buffer boards went out. Worst case scenario is your panel went out. But you won't know without replacing the other boards first.
Apr 10, 2012 | LG 42PC3D 42 in. Plasma Television
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
LG 50PX1D (Popping noise)
Hi you need the y-sus board. You May find it @ Thanks.
Sep 21, 2009 | LG 50PX1D 50 in. Plasma Television
Screen just suddenly went dark!
If you can see a faint picture with streaking you most likley have a defective Zsus module Part Number 6871QZH036B Description PWB(PCB) ASSEMBLY,DI List $226.14 Please rate my info
Feb 20, 2009 | LG 50PX4DR 50 in. Plasma TV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
295 people viewed this question
Computer Repairing
Computer Repairing
