The screen went dark on our year and a half old LG 50" flat screen. Sound works, can see screen when you shine a flash light on it. Replaced the power supply/LED board on it and it didn't fix it.
Service code: 50LN5100-UB.BUSYLJR, what part should I replace now?
  • 100 Answers
SOURCE: 1 year ol 52 inch flat screen with new power supply cycling.
Still sounds like a power supply issue would it still be under repairers warranty
Posted on Jan 07, 2010
  • 15 Answers
SOURCE: toshiba tdp-s3 projector
It sounds like the high voltage portion of the power supply (ballast). Turn to the solder side of the P/S board and orient it so the silkscreen is legible. Check for burnt resistor R573, 2Kohm. It's center of board, 3/4" from bottom edge. If that's OK, check 3.3kohm resistors R621, 622, 625, 628, 629, and 630. They're in the top right corner. They tend to crack. Good luck.
Posted on Feb 20, 2010
welcomejee
  • 10594 Answers
SOURCE: what is the problem with
Did you replaced both back light inverter boards in your Dynex 37 inch tv?
What is model number of this tv?
Does power supply board provide correct voltages to back light inverter boards?
Let me know above info to diagnose problem.
Thanks.
Posted on Nov 12, 2010
vinceisaac
  • 2432 Answers
SOURCE: lg 47lk520 reset
tried first to disconnect the supply connector going to the inverter board for back light just to ensure if their is no shorted component here. and then turn the power on again if the light stay then the inverter board was the cause why won't power on. by the way did you make a voltage checking at the power supply board does it have correct output voltages 5v,12-16v and the 24v.
Posted on Sep 19, 2012
zanepauldba
SOURCE: i have a vizio razor led m470vt. power light flashes dim to bright. no screen but have 120v into board. replaced power board but did not fix????
I have this same problem with my Vizio. Model E601i-A3
60" LED, believe. Maybe 64"
Anyway, the solution is much simpler than these other answers make it sound. 1) Unplug tv from wall.
2) Unplug all external devices (all HDMI ports, any cable hookups, any rgb/vga connections, and any speakers attached.)
3) Unplug USB drives/attachments.
4) Plug TV back into outlet.
It should power up just fine. Then you can go ahead and reattach all your devices WITH THE TV SCREEN ON, reattach your USB sticks and you should be good to go.
Every time the TV is moved or is unplugged for any period of time, follow these procedures. The real culprit is the USB drives - the TV, like many laptops I've had, can't boot up with them attached. Thankfully once the TV learns what they are they no longer have to be removed.
Posted on Nov 13, 2014
How do I get the picture back on my LG LED 50 flat screen? Sound works, no picture.
-You have a bad panel. Led arrays internal to the panel are defective. Replacement cost exceeds economical repair.
Apr 27, 2015 | LG Televison & Video
I have had my 55" Vision for a year and a half. Today I was watching a movie and the picture went dark and audio stayed on. If I turned the TV off and then back on it would light up with no Vision logo...
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. If you see a faint picture, you either have a back inverter or a bad backlight bulb.
Sep 02, 2013 | Vizio GV42L 42 in. LCD Television
Flashing black and white squares instead of picture on screen.
This might require attention by a qualified service technician.
Jul 13, 2012 | LG 50PC3D 50 in. Plasma Television
Norcent plasma had smell of electrical burning and
get real bright flashlight shin close to the screen in dark roomand try to push the menu button if its the bulb you'll see some picture with flash light shining that shows your backlight is out
Feb 15, 2010 | Norcent Technologies PT-4291HD 42 in....
Loud pop from projection TV, then no screen
Ur power board it dead.Replaced capacitors that puff up or pop open.Or replaced the whole board.
Dec 23, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
LG 50PX1D (Popping noise)
Hi you need the y-sus board. You May find it @ partstore.com Thanks.
Sep 21, 2009 | LG 50PX1D 50 in. Plasma Television
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Screen just suddenly went dark!
If you can see a faint picture with streaking you most likley have a defective Zsus module Part Number 6871QZH036B Description PWB(PCB) ASSEMBLY,DI List $226.14 Please rate my info
Feb 20, 2009 | LG 50PX4DR 50 in. Plasma TV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
548 people viewed this question
k24674
jasbo
jasbo
