Question about David White 44 8834 1 22x Level Transit Package
How to fix crooked cross hairs on David White transit level
  • Sandi Robert
    Sandi Robert Apr 27, 2015
    David White Realist Meridian model # L6- 20
    Top Expert:
  • David Master
  • 52,099 Answers
Don't believe that is a consumer fix . has to be sent in to them
Posted on Apr 27, 2015
2 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: My 50 inch 5 year
you need new convergence ICs. post your model number and I will post the correct IC numbers for your model and a link where you can get them with free instalation instructions.
Posted on May 29, 2008
What is a cross hair
A crosshair is a part of the aiming device on a gun, as in I have it in the crosshairs
Feb 02, 2017 | Optics
How to change battery in remote for a 1997 BMW 528i, when trying to change the battery and tried to see if it worked nothing happened
You have to take the old remote key back to both Mercedes or BMW to change the battery. Little profit motive there!
Mar 08, 2014 | David White 44-8871 LT8-300P Universal...
Cross hairs stick, tap instrument it corrects it
Put it on its side and bang it on a counter...not too hard now
Nov 11, 2013 | David White 44 8834 1 22x Level Transit...
How to fix loose cross hair on david white transit
This is how I replaced the cross hairs on my David White 8080. Disassemble the tube piece nearest the eye. There is a small ring that holds the hairs, it has small marks on it to indicate where the hairs are to be attached. Use a large lighted magnifying glass. Remove the old hairs. Take some plastic model glue and using a toothpick, place a very small amount on the marks to anchor the new hairs. This type of glue will produce strings or "hairs" when beginning to dry if you use a toothpick to stretch them out. Place some drying glue (several seconds old out of the tube) on one of the marks, and pull the toothpick away (creating a hair) and pull it across the ring to the mark on the other side. Repeat for the second cross hair. With a little practice you can make some very nice cross hairs.
Dec 16, 2012 | David White 44 8834 1 22x Level Transit...
I have a berger instruments transit level model 200B and have no cross hairs to center it when i look through it , is there a fix??
Yes there is, but I don't think you can do it your self. There are places that fix nothing but levels and transits. I don't know what happened to your lines, must have been dropped or something. I had a level repaired once, it was fairly cheap. I would contact Berger first. Hope this helps.
Aug 09, 2010 | Speed Berger Instruments Line Transit -...
How to adjust a David White transit level
I just assisted a friend "re-calibrate" his D.W. L6-20 Level Transit. Follow the following steps.
1. Set up the tripod & transit in the garage. Get the platform with the protractor, close to level.
2. Position the telescope at "0". The telescope should be over 2 of the adjusting screws.
3. Adjust the screws to get the top bubble close to level. Adjust with a screwdriver the spring loaded screw to get the bubble closer to center.
4. Rotate the scope 180 degrees. Note the difference in the bubble position. Split the difference from the first bubble location by adjusting the same top screw.
5. Rotate back to 0. Adjust the same top screw to split the difference in bubble position.
6. Rotate back to 180 degrees. The bubble should be off by the same amount. Adjust the 2 bottom screw to place the level in the center.
7. Rotate back to 0. The bubble should not move.
8. Rotate to 90 degrees and adjust the 2 bottom screws to place the bubble in the center.
9. Rotate to 270 degrees. The bubble should be centered.
10. From this point on, all you need to do is place the level on the tripod and position it over your reference point with a plumb bob. Adjust the bottom 2 screws at 0 and again at 90. The level is set to use.
Sep 05, 2009 | David White 44 8834 1 22x Level Transit...
David White 44 8834 1 22x Level Transit Package Logo
794 people viewed this question
Top David Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a David Measuring Tool and Sensor Expert? Answer questions, earn points and help others
