Question about Refrigerators
My freezer froze up and I unplugged it long enough for it to thaw out,when I pluged it back up the interactive display flashes like this but both refrigerator and freezer work !what should I replace
  • Refrigerators Master
  • 5,323 Answers
Fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
Posted on Apr 27, 2015
eagle338
  • 4889 Answers
SOURCE: frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Posted on Sep 02, 2008
  • 400 Answers
SOURCE: Whirlpool Top-Mount Refrigerator Freezer warm, cracking noise
8yr old? Buy a new one. The cracking sound is from expansion and contraction of the cabinet and ice cooling or defrosting. It can be as simple as a bit of a top up of refrigerant, but can also be that your compressor has worn down the valve plates and therefore is not producing sufficient pressure throught the system.
Posted on Mar 06, 2009
bestdarngood
  • 3037 Answers
SOURCE: Refrigerator works, freezer doesn't
The part that is usually the issue on this model is the defrost thermostat.
I usually test it for continuity while its frosty with an ohm meter. If you don't have an volt/ohm meter, you can get a cheap one at Radio Shack.
It clips on the top right side of your evaporator coil. It is part 23 on the diagram at this website http://content.searspartsdirect.com/lis_png/PLDM/P0070077-00003.png
Let me know if you need anything else
Benjamin
Posted on Apr 26, 2009
rockitman187
  • 2559 Answers
SOURCE: Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Posted on Aug 05, 2009
kel1guy2002
  • 3740 Answers
SOURCE: refrigerator/freezer won't stay cold.
With the defrost timer being replaced already it sounds as if the repairman is not looking at the real problem. Unit works for 2 days then things start thawing. Hint Hint... it is not defrosting. There is a heating element inside the freezer section attached underneath the internal tubing that melts the ice every 6 to 8 hours via the defrost timer depending on the defrost timer installed. To prove that it is not defrosting..... just unplug the unit and place a stand fan blowing into the freezer for about 90 minutes. I would bet that once you plug it back in it wil work for 2 days and the problem once again repeats. With 2 calls on the same unit and you still have the same problem I would be calling the service people back and demand they fully troubleshoot the defrosting element and thermostat. Personally this is an unstatisfactory performance of an in home service by a repairman. With the exception of a new part if required, they should wave any labor and service call fees.
Posted on Jan 02, 2010
Testimonial: "Thanks! The repairman also replaced the thermostat, though. What should I ask him to do this time? Replacements were: timer, thermo, timer."
Not freezing water pooling door shelves
sounds like coils froze up... in freezer about halfway down there is a panel. unplug fridge.. remove panel, use blow dryer to thaw coils. this will cause a lot of water to come out. once they are thawed out, replace panel, plug it back up and it should be fine... sounds like someone left it cracked open overnight.
Oct 25, 2013 | Frigidaire GLSZ28V8GW SIDE BY SIDE...
Freezer won't stay cold
What is the model number of your unit?
Feb 10, 2013 | Gladiator Chillerator Top Freezer...
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Freezer freezes than thaws completey all items thaw out???
call the repair man now they have a twenty four hour service,they can loan you a refigerator,to use while youres is getting fixed it could be the compressior is every thing clean from underneath is the defrost pan full of water is the defrost drain tube blocked is the vent clean from lent. this needs to be checked twice a month,even if you dont think so. try unpluging it then pluging it back in is it the gp plug,did the breaker go off is the light on?let me know
Aug 29, 2010 | GE Refrigerators
Can't open bottom freezer draw. It seems to be locked. How do I get it open?
IF YOU HAVE AN ICE MAKER IT MAY HAVE OVERFLOWED AND FROZE THE DOOR SHUT. AND IF YOU ARE SURE IT IS NOT FROZED WITH WATER THEN YOU ARE GOING TO HAVE TO FORCE IT. OTHER WISE BE SAFE AND UNPLUG. LET IT THAW AND TRY AGAIN AFTER 24 HOURS.
Apr 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water freezing in bottom of freezer
There is a drain for your freezer that is pluged.It may be pluged with ice or dirt.Try unpluging your fridge until it is completely defrosted,4 to 5 hrs. with doors open.
if there is dirt in it it may flush out or your heater element for the defrost is not working.
Dec 18, 2008 | Whirlpool Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Water in freezer
sounds like you got a pluged freezer drain... take the back off freezer and unplug drain might be froze over with ice from being plugged
Aug 31, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer of refigerator (coils keeps freezing over)
I had the same problem, i took mine outside and spayed degreeser on the coils and power washed it off. the coils get built up with dust. make sure you dont have it pluged in when power washing it. lol. good luck
Jul 28, 2007 | Hotpoint RLA80 Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
