It will not hold auto scan programing after it is done going thought the channles it keep only one channel is there away to reset the tv it's self
It was hooked up to a box now it is hooked up to straight line cable
    Genius:
  • 1,585 Answers
Auto search then store
Posted on Apr 27, 2015
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
      forums.toshiba.com/t5/Televisions...To-TV...Program-Channel.../345660
    Feedback
    LG LED TV won't show program information or channel name ...
Jan 13, 2016 | Televison & Video
Tv will not program channles only gets one channel.it was hooked to timewaner cable now it is a straight line cable.
straight line cable to what they need an antenna or something on the outter end do another auto scan .hopefully you will get more channels G L
Apr 27, 2015 | Televison & Video
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Keeps telling me to run an auto channel scan
Check and replace its main system control memory IC. It is faulty. It does not hold the data. Gopakumar Gopalan Google
Feb 26, 2014 | Orion 24RTC 24 in. TV
No channels listed on tv after reset was done
The entire memory was wiped off as you had reset the TV . Soo all you need is to open the menu and choose the settings, choose the auto programming and scan.
Once the programs listed on your cable or network has memorised you can shift the channels to the required selected program numbers to your desire.
Sep 06, 2011 | Westinghouse Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
I can get to the menu settings, go up to the auto channle search,,, but my tv won't do the search,,, what can i do ?
I have the same problem. Cable went out, hooked up an antenna and it scanned ok. Hooked up a diff amplified ant, worked the same. So watched videos. Next morning tuner would no longer scan or add channels. Now it will not even factory reset. Get to Auto Scan and it goes no further, cable or air.
Mar 28, 2011 | Syntax Olevia 537H Television
I have connected the tv to cableand I can only recieve channels 2,4,5,9 & 13. How do I set up the tv to receive the remainder of the channels? Thank you
do a channle auto scan, you need to select CATV in order to scan for cable channels. after the scanning process, all the channels you can get should be on your set.
Mar 19, 2011 | Sharp Televison & Video
I dont have satelite or cable how do i get tv channels?
you can go and get an indoor digital antena from any electrical store and hook it up. you can then scan for the local channels.
Jun 18, 2009 | iLO 3200 32 in. LCD Television
Channels won't go past 38
Make sure cable Tv is hook up directly to TV then go to the tuner menu and do an auto scan or auto search for channels that should fix your problem.
Mar 07, 2008 | Proscan 32LA30Q Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
