Question about Air Tools & Compressors
I cant get my compressor to spark. How do I set my points and what else should I check?
The machine is a IR gyroflo 85
  • 2,210 Answers
IR is a big company. Go online for handbook or tech help.
Posted on Apr 27, 2015
23009848 - CONTROLLER, IR-S3 factory settings
usually cant adjust when the unit is running make sure it is off and the emergency stop button is not pushed in
Mar 17, 2014 | Air Tools & Compressors
78 ds80 no spark
This ignition design relies on proper setting of the points in relation to the magneto to produce a spark. It is possible that your aligning pin sheared causing the magneto to be out of place in relation to the points opening. Dirty points, improper gap, and a bad coil will all result in a 'no-spark' condition. Check out the attached video. It is not your bike, but the procedure is the same. How to Set Points
Mar 05, 2014 | Motorcycles
Ir 85 error code E000015-0000
hello
8500 IR copy machine
E00015 - 0000 errors.
Please guide me.
I also translated by the site you have to translate the sentences. So you have the goodness wording is easy.
Thanks
Nov 19, 2012 | Canon imageRUNNER 8500 Copier
I have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
I have an ingersoll rand P185WJD Compressor that
possible that one of the protections switch it off check oil levels motor and screw can also be a sensor, can check these by briging them one by one. first indication is control lamp. or possible fuel problem check filters and tank. also check wiring complete. is weak point for ir machines. good luck.
Feb 10, 2010 | Air Tools & Compressors
85 horse boat motor
check the spark plug and check the fuel filter. if still no response check if there is spark comming out of the spark plug
Sep 22, 2009 | Boating
Does an 85 johnson outboard motor 15 hp have
Not ignition points as a set of breaker points as we know it.The timing is set from magnets set under the flywheel.Hope this helps
Sep 02, 2009 | Sport & Outdoor - Others
Ir 3300
i have an IR 3300 (used) i have given TCP/IP correct with machine and PC also. ping command is working properly and IR Machine also response from the host and also i'm success output (Printout) but can't scanning. I have scangear also tried but the messeage appear "the spacified IP address is invalid or scanner is not connected to the specified IP" but my IP address is correct. (both side) i know that after this my Machine will be online from System button but there is no software. i cant solve my problem
how can i connect my Machine from PC
Dec 18, 2007 | Canon imageRUNNER 5000 Copier
Air Tools & Compressors Logo
83 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
