Question about Sewing Machines
The stitch display is broken can i get this mended, I can use the machine but the display is not showing
  • Sewing Machines Master
  • 1,860 Answers
You'll have to contact a sewing machine shop in your area and ask them if they can fix it
Posted on May 29, 2015
My brother electric super ace 11 sewing machine stitch program stopped working can you mend it yourself!
Depends what exactly is the problem. However, if it is a computerized model, it would probably be best to take it to a service technician.
Jun 06, 2017 | Brother Sewing Machines
Brother ls 2020, 3 dials for tension, ALL I WANT TO DO IS MEND. what is the # just for mending? why are these machines so hard to work?
A manual may help:
User Guide Manuals LS 2020 Others Brother
There is only one tension dial, the round knob above the needle. Standard setting is the midway point between high & low number. The other two knobs are the stitch length and stitch width dials. With the stitch length knob, zero will make the machine sew in the same place, so you'll want to set it probably midway (the higher the number, the longer the stitch). With the stitch width dial, zero will sew a straight stitch--the higher the number the wider the stitch). Spend about 30 minutes reading the manual and you'll probably be able to use your machine. ALWAYS RAISE the presser foot when threading the top thread so the thread will seat properly.
A video may also be helpful:
https://www.youtube.com/watch?v=UC4ci-t5M60
RELAX!!!
Mar 30, 2017 | Brother Sewing Machines
How do I change the stitch width and length from mm to inches on an Ellure. I've changed the overall settings to inch, but the individual stitches are still showing up in metric.
The inches to mm display is only changed in emb. mode. The stitches will still be shown in millimeters. It is the nature of machines manufactured in todays world.
Jan 01, 2015 | Sewing Machines
1249380 kenmore sewing machine
Depends on what stitch you intend to use. I do a lot of mending with a three step zigzag set to maximum width and minimum length -- see: http://www.picturetrail.com/sfx/album/view/24395076 A wide, short zigzag stitch is another popular choice, as is a straight stitch worked back and forth over the area: http://www.running-w-scissors.com/2014/01/tutorial-patch-mend.html
If you're just mending a seam that's come unstitched, a straight stitch or zigzag stitch similar to what's already in the seam is what you're looking for.
Feb 05, 2014 | Kenmore Sewing Machines
Dogs motor?
Does it have a stitch length dial which ranges from 4 down to 0 and then into negative numbers? If so, the negative numbers will be reverse stitches. Some machines have this functionality and its very happy for doing mending or stitching in awkward places to sew backwards without having to hold the reverse button.
However, if yours is only sewing backwards when stitch length is set to 2, 3 or 4, then its probably a drive problem internally. Don't think your machine has a seperate motor for the feed dogs, probably a gear driven shaft in the free arm.
Dec 06, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
What would be a "stretch" stitch setting?
For a stretch stitch use a narrow zig zag stitch. Use a ball point needle with knit fabrics.
May 30, 2017 | Sewing Machines
Ordinary straight stitching/Husqvarna 2000 SL
ordinary straight stitching is normlly the first button (only one) in the stitch selection area. Look for symbol/picture showing a vertical broken line on the displays.
Sep 02, 2009 | Husqvarna Viking 1
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Broken stitching
if the bottom stitching is bad that means something is wrong with the top thread. If the top stitch is bad that means the problem is with the bobbin. Wind the tension the whole way in and then back it off to number 3 and then rethread it. When you hold the thread coming out of you bobbin case it . The whole thing should fall into your hand slowly not real fast. There is a screw on the metal bobbin case to adjust the tension on that. That is if you have a pull out metal bobbin case.
Jan 06, 2008 | Brother XL-5130 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
