Question about Building Materials
The garage door will go up automatically and the wall mount loses power.
  • hpgwva Apr 27, 2015
    Hi George Locklear, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    New Friend:
  • 130 Answers
One of two things a short in the wires or a bad circuit board.. I've address the same problem twice in the last week and it was the board.
Posted on May 03, 2015
  • 2,210 Answers
Shorted out wires to the wall mount by a staple or something
Posted on May 01, 2015
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
  • 3197 Answers
SOURCE: Sear garage door wall mount contol light keeps blinking
One of the buttons has a lock icon. Hold that button in for 3 seconds.
Posted on May 17, 2009
  • 3197 Answers
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: The garage door wall remote flashes and car remote won't work
Usually this can be corrected by programming the opener. Locate the smart/learn button on the back of the opener. It is just to the left of all those white wires. Hold the button down on your remote and then press and immediately release the smart/learn button. Do this for each remote you have.
Posted on Jun 30, 2009
  • 3197 Answers
SOURCE: The wall mount control for my sears/craftsman
Press and hold the button with the lock icon for 3 seconds. This will stop the blinking and your remotes should work.
Posted on Nov 11, 2009
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Craftsman opener that will not open with the wireless keypad but it will close with it, and all other remotes and wall mount work fine.
First thing make sure the battery in the keypad is good. If this is not the case then your keypad is losing signal strength and will need to be replaced.
Mar 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens from button inside garage not by bour remotes in our cars ( 2 remotes )
FIRST CHECK TO SEE IF THE LOCK/VACATION BUTTON ON THE WALL CONTROL HAS BEEN ACTIVATED. THE LED ON THE WALL CONTROL WILL BE FLASHING. - SIMPLE SOLUTION PUSH THE LOCK BUTTON AND HOLD FOR 2 SECONDS TO TURN OFF LOCK FUNCTION.
SECOND TRY TO REPROGRAM THE REMOTES TO THE UNIT - THEY WILL SOMETIMES LOSE MEMORY IN AN ELECTRICAL STORM.
IF REPROGRAMMING DOESN
Nov 13, 2010 | RTO Automatic Garage Door Closer
No power to wall mounted door switch need wiring diagram
Wall mounted door opener remote should get power from the main console once that is powered up. If you have wired correctly onto to the wall mounted unite and onto the main console and upon powering up the main console there is still no "life" on the wall mounted unit, I would check if there is actually any current coming it. You can easily do it with volt meter (Harbor Freight tools have a very good one for $7 or so). If no active current, call Chamberlain.
Oct 05, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Apparent internal short
Absolutely. You need to pull the board and check for loose connections especially around the small transformer. Some are hard to see and you might need to just touch it up with a small soldering iron.
Jun 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wall mount not opening door. Looks like its not getting power.
You may have disturbed the wiring leading to the wall control. It connects to terminals 1 and 2 on the rear of the motor unit. The wires are color coded and must be connected correctly. The solid white wire goes to terminal 2 and the white wire with red tracing goes to terminal 1.
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dec 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
140 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
