Question about Food Mixers
Where can I get repair parts & repair manual for my Frigidaire FD5125 All-in-One Mixer, Meat Grinder, Blender, 220 Volts?
Plug it in, no lights & doesn't work at all. Fuse & cord okay. need to know where I can get parts.
    Top Expert:
  • Food Mixers Master
  • 45,527 Answers
Go on line to the manufacturer customer or spare parts departments and make enquiries as to service centres near you
Posted on Apr 27, 2015
My food disposer has no sound I need help. Could you help me?
If you open the cabinet door under the sink, you should be able to see the disposer motor. On the bottom or side, there should be a small bump that is the reset button. Push the button in and it should work again.
If it still does not work, make sure that the power cord is plugged into the outlet.
Still not working? Check the fusebox for a blown fuse or tripped circuit breaker.
One last idea: if the outlet that the disposal is plugged into is a GFCI protected plug, there will be a TEST and RESET button in the center of the outlet. Unplug the disposal cord, press the RESET button on the outlet, then plug the disposal cord back in.
Aug 31, 2015 | Food Mixers
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Why won,t it start
Make sure you have power at that outlet. If so, unplug and look for damaged cord. Then open and look for blown fuse.
Jul 22, 2014 | Farberware 12-Cup Food Processor w/ 4-Cup...
Kitchenaid mixer works intermentily
How old is the mixer? If older, check for possible short in cord either at plug end or at mixer body. Best to disassemble and test cord with VOM meter. Often cord and break internally and show open circuit only when cord bent a an angle.
Next< i would look at the speed mixing switch, the mechanical part, not the electronic board, for defect such as dirty contacts.
If above do not work, then check motor brushes. And, only then I would suspect electronic controller.
Please psot Mixer model and serial number rfor further assistance
j
Nov 29, 2013 | Food Mixers
Kmix mincer not rotating
Hi, it sounds like a broken gear.
Send me your email
Aug 12, 2013 | Kenwood Ax950 Attachment For Kmix Stand...
Have a PVi8B mixer that has stopped working suddenly. Doesn't do anything when you flip the switch to "ON" are there fuses that could be the problem?
Does the blue power light come on when you switch it on? There is a 5amp fuse in the supply cable.Open the wall socket plug of the supply cable (unplugged of coarse) and check fuse and connections.With a multimeter check continuity of the three wires from the plug to the other end of the cable.If this is all good then you have an internal fault.There are fuses internally as well but this should be refered to a qualified technician.
May 10, 2013 | Food Mixers
Where can I get the service manual for this model?
Hi, Bricklayer.
You can find the parts diagram here: http://www.mendingshed.com/ka6pro.html
And you can order replacement parts there.
How old is your mixer? There was a time that they shipped with a plastic gearbox, and it frequently failed. Kitchenaid went back to all-metal parts after a while.
I have the same issue, but there were no parts - just an attachment drive gear that does not turn.
Mar 22, 2013 | KitchenAid KP2671 Professional 6 Series...
Need to adjust clutch on hobart 4346 meat grinder how do you do it?
On the 4346 mixer/grinder the clutch can't be adjusted. It is a Moorse clutch and will need to be replaced. If you ate handy buy the rebuild kit for the bottom end from Hobart. It's not cheap but once it's done it will last for years. Hope this helps, Food luck
Dec 16, 2012 | Hobart 4346 Meat Grinder Mixer Chopper...
I bought it in the states (110V) and by mistake my wife pluged it into 220V. I took the top cover of and I could see that some parts on the control board are black. is there any way to find the drawing...
i believe if the board is black, it has burned out. Check the part no. of the control board. It could be 9707220 or some other no. Search for the spare part online. once you get it replace the board and you're good to go! BTW, the board is "plug and play" doesn't need any soldering etc. Just plug in the wires and it'll work.
Apr 03, 2011 | KitchenAid KT2651X Epicurean Stand Mixer
Food Mixers Logo
111 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
