Question about Garden
I drove in drive 2 on the freeway and now my car is shaking like an old grumpy lawn mower, what coyld the problem be?
    Top Expert:
  • 10,875 Answers
Overheated transmission,have it looked at
Posted on Apr 27, 2015
  • Norine Medina
    Norine Medina Apr 27, 2015
    Johnny is it gonna be expensive to repair
  •  johnny rebel
    johnny rebel Apr 27, 2015
    probably,have a male take it to get an estimate,so,they dont take advantage of you,
    Top Expert:
  • 2,899 Answers
Possibly could be warped brake rotor.
MNfisherman
  • 11896 Answers
SOURCE: lawn mower won't start
Carb is most likely gummed up and will need cleaning. Anytime a gas motor is store through a season, you should use a product called "stabil" in the gas to prevent gumming up. Also check that there is a strong spark coming from coil. To do this, remove spark plug, hook it up to the coil and set it on motor block and pull it over. You should see a strong spark. If you don't see the spark, then either the coil is faulty or the magnet from coil to flywheel is not getting good contact.
Posted on Jul 03, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
  • 3 Answers
SOURCE: old snapper riding lawn mower with the handlebars
Usually the drive disc . Look under mower at rear, you will see a wheel with rubber ring on outside diameter. I think, it is four small bolts holding it on. Take off and replace, will usually solve problem.
Posted on Apr 25, 2010
RonInFla
  • 86 Answers
SOURCE: Toro Lawn Mower 20017 serial # 250000001 shaked and smoked while
drain the oil...the gas seeped into the cylinder and into the crankcase...fresh oil, a clean plug, should do the trick...
Posted on May 02, 2010
Zero Turn Lawn Mower shakes on full throttle
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 14, 2017 | John Deere EZtrak Z225 Zero-Turn Riding...
I have a John Deere LA145 lawn tractor. When I engage the mower, a loud noise (grinding) comes from the mower. What could be the problem? The tractor is 2 yrs old.
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Aug 26, 2011 | Garden
19.5hp 42" cut. Shakes when mower is engaged to cut
how hard does it shake? and does it mow?
most lawn tractor will shake a quick almost violent shake at first then it should vibrate quite a bit more while you are mowing this is just caused by the power being pulled from the motor to power not only the drive but the mowing deck. its normal.
if its worse than what i described you may have a bigger problem, if there is excessive clanking from the deck your blade may be loose/installed upside down.
Aug 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steering and real bad vibration in front end
That is known as "the death wobble" for very obvious reasons. You need to install steering dampeners . They look like shocks and they mount between the drag link and the frame. They will cure the problem. Don't delay putting them on your Jeep. Hope this helps.
Jul 04, 2010 | 1997 Jeep Grand Cherokee
May 02, 2010 | Garden
Clean old petrol can thoroughly
Not to worry, just drain out any old gas, put in a little new gas, shake it a little, pour that out fill it up and use it. If its bad varnished w/ old gas use stuff called Seafoam pour it in, shake it up let it sit over night and pour that out use like normal.
Aug 01, 2009 | Garden
Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Oct 13, 2008 | Poulan "Poulan" Push Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
