On the console what switches go to what. I need a console diagram.
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
C2255 treadmill - everything works but the console light no longer comes on - nothing in manual to show what the problem could be.
If the console takesbatteries, replace them. If this does not work or your console does not requirebatteries, check the reed switch or optic sensor. Reed Switch:Unplug the treadmill and remove the motor hood cover. The reed switch is mountedon the frame next to the front roller pulley. There is a magnet glued into thefront roller pulley. When adjusting the reed switch, make sure it is pointingdirectly at the magnet. Move the tip of the reed switch within 1/8" of themagnet. Also, check to see that the wire is not damaged, and is connected tothe console.
See the diagram adjust for 1/8"
After that: Do the next: 1) Tight the flexible cable from keypanel vs Display board.2) Tight the connector from Display Board vs Lower Board( Main Controller Board). See the block diagram that I did how the main controller board has aprox 90% of function from the any treadmill
Nov 26, 2011 | Nordic Track C2255 Console (treadmill)
Need to know why my washer does not wash, rinse or spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Jan 07, 2011 | Kenmore 22622 Top Load Washer
MODEL 110-24722300 KENMORE WASHER. LID SWITCH DOES NOT WORK AND HAS COME LOOSE. HOW DO I PUT IT BACK TOGETHER?
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024722300/0582/0153200?pathTaken=
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet. See the Sears diagrams on the control panel and cabinet to see where / how the switch connects.
Nov 24, 2010 | Kenmore 22422 Top Load Washer
Washing machine doesn't agitate or spin. The switch lid is not working correctly. We need a diagram of the machine to know how to take it apart.
Nov 19, 2010 | Washing Machines
I need the installations instructions for a Kenmore washer Mod 11020882990 for the lid switch Stella
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020882990/0582/0153200?pathTaken=
Oct 26, 2010 | Kenmore Washing Machines
Replace on/off swich
You dont need a diagram! buy a spare from ebay and use a low watt solder iron to repair (18 watt recomended) or see ebay ad no220548419221
Nov 20, 2009 | Nintendo DS Lite Console
Trying to disable the dryer's loud buzzer
The wiring diagram is located in the slanted panel above the washer door
Jul 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Install alarm system
Battery- RED RED (+) IGNITION SWITCH HARNESS (2 CONST WIRES)
Ignition 1- PINK (+) IGNITION SWITCH HARNESS
Starter 1- YELLOW (+) IGNITION SWITCH HARNESS
All Door Trigger- WHITE (-) SMALL HARNESS BELOW ASHTRAY
Trunk Trigger- RED/BLACK (-) AT TRUNK LIGHT
Parking Lights- BROWN (+) BEHIND FUSEBOX UNDER CONSOLE OR SWITCH
Power Unlock- WHITE (+) POSITIVE TRIGGER OR DRIVERS KICK PANEL
PowerLock- LIGHT BLUE (+) IN CENTER CONSOLE "BEHIND FUSEBOX"
Apr 12, 2009 | Vehicle Parts & Accessories
Overhead console wiring diagram
Compass/Temp w/o Trip function
Yellow - Key on 12v
Black - Ground
Light Green/ Black tracer Ambient air temp sensor At about 70 deg I have almost 10K ohms resistance. Just for a point of reference.
Dark Green VSS
Brown Goes to the dimmer switch that adjusts the brightness.
Gray Goes to headlight switch so the display will dim when the lights are on
Mar 10, 2009 | 1998 GMC Blazer
Overhead console dodge grand caravan 1992
Have you tried a junk yard? I found a match to my console, just different color.
Jun 14, 2008 | 1992 Dodge Grand Caravan
Washing Machines Logo
Top Washing Machines Experts
