Question about Dacor DCM24 Convection/Microwave Oven
How do I change a micro switch?
Heating has stopped and the turntable stopped
    Top Expert:
  • Dacor Master
  • 10,875 Answers
How do you know the switch is bad?maybe it is the fuse thats inside the microwave
Posted on Apr 27, 2015
Why would the turntable stop turning and the unit stop heating?
hi,
there is a micro switch that signals when the door is closed. this tells the machine that it's okay to start the turntable and heating process.. if the micro switch breaks or shorts out then the switch does not send the signal so the machine does not work.
hank
Sep 06, 2014 | Sharp R-1505 Microwave Oven
My Micro will not heat and it keeps beeping I can not get it to stop...
Its likely beeping as it is not heating, I presume light goes out when door closed and a turntable turns or not?
I can provide possible reasons for no heating etc.
Dec 21, 2012 | GE JES1142SF Microwave Oven
Micro stopped working tonight
it would be the magnatron thats blown this will stop it from creating heat as to the turn table going at same time tricky one. either way the magnatrons are expensive and very dangerous to replace scrap it and get a new one
please remember to rate this thaks
Jul 04, 2010 | Estate TMH14XL Microwave Oven
My Maytag microwave stopped heating. Everything
Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
Let me know how this works out for you.
Benjamin
May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
My sharp R-798 has stopped heating food and the turntable no longer rotates?
Please check your door safey interlock micro switches.
If you need help with this, please let me know.
What frequently happens is because you probably open the door while the oven is running, (like most of us do) the little micro switches get burned and eventually cannot tell the oven that the door IS, indeed, closed. When the door is "open" (forget that you know the door is closed - the MACHINE needs to know it too) the oven will not turn on the heat.
If you need more info, let me know please.
Oct 18, 2009 | Microwave Ovens
Unit turns on, turntable turns, but nothing heats
Classic symptoms for failed door interlock safety switches, though it could be other trouble.
Remove the cover and check the operation of the little micro switches that operate when you close the door.
DONT TOUCH THE SILVER CAN - LETHAL.
If you regularly open the door while cooking, the contacts in these little switches become burned. When burned badly enough, they cannot make contact. When they cannot make contact, the mocrowave doesnt know the door is closed and will not turn on the magnatron resulting in no heat.
If you need more help, let me know.
a
Sep 27, 2009 | LG LRM1250 Microwave Oven
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Sharp 1505 over counter microwave
It's almost certainly not a switch issue. If the primary interlock (lower door switch) were bad, the turntable and cooling fan would not come on and it would not heat.
If it heats, but the turntable won't work, the motor is likely bad.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
We have the complete service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
Nov 07, 2008 | Sharp R-1505 Microwave Oven
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Dacor DCM24 Convection/Microwave Oven Logo
102 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
