Question about Mercedes-Benz 2000 S430
C1000-017 Control unit
What does the trouble code mean?
    Top Expert:
  • Mercedes-Benz Master
  • 10,875 Answers
Crankshaft Position Camshaft Position Correlation Bank 1 Sensor 'B',,,,,,
Posted on Apr 27, 2015
My remote control displays 'HI' when the unit is off. The a/c is working fine, and this goes away when I turn it 'ON'. I would just like to know what this code means?
read the user manual in trouble shooting but if the unit is functioning as it should , it may be a simple greeting as in hello meaning that it is ready to start work
contact your service dealer for what it means
Sep 01, 2016 | Heating & Cooling
Sharp mx1204 error f1-90 what is causing the error?
Hello Awelani,
The error code of F1-90 means the following;
Communication trouble between the decurler and the downstream units. OR possibly;
Communication trouble between the decurler and the units connected to the downstream of the decurler.
CAUSE; Noise on the communication line, control PWB trouble, disconnection of connector or harness.
REMEDY; Turn OFF/ON the power. Check connection of the connector between the decurler unit and the downstream units of the decurler. Replace the control PWB of the downstream units of the decurler.
A complete error code list can be found here; Error Codes Sharp MXM1204 page 11 Use the < and > to go through the complete list.
Good Luck!
Rich Lilja
Feb 19, 2015 | Sharp Office Equipment & Supplies
I have a 2007 hyuandai Tucsun that has a trouble code reading C0700, what does it mean?
There are no "C" DTCs. If you mean P0700 It indicates there is a transmission control system problem. Probable causes:
1. Faulty sensor or solenoid
2. Control unit software in need of updating
3. Faulty PCM or ECM
4. Transmission system malfunction
May 18, 2014 | 2007 Hyundai Tucson Limited
Panasonic CZ-RTC2 with a fault code E04 does somebody know what that means?
Hi
This error means that your outdoor unit can not communicate with one of the indoor units.
most probably one of indoor units has a trouble.
Oct 22, 2013 | Panasonic CZ-RTC2 Wired Timer/Remote...
2006 dodge 1500 hemi-trouble codes p0700 and p0800, what are they?
the P0700 means Transmission Control System (MIL Request)
the P0800 means Transfer Case Control Circuit
hid conversion kits
Aug 27, 2012 | 2006 Dodge Ram
We are getting code F11. What does that mean?
Hello. the F11 trouble code means Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
These are circuit boards within the machine and one of them will have to be replaced. Most folks leave this job up to the service technicians.
Feb 02, 2010 | Kenmore 46462 Front Load Washer
What does F11 error code mean on a whirlpool washing machine?
This code indicates a serial communication error, meaning communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly. Check the wiring harness connections at the CCU and the MCU. Unplug and reseat and make sure there is no corrosion. It can also indicate a problem with the door lock relay on the control board, a faulty hall sensor, or the mcu or ccu themselves. I think that I'd recommend getting an appliance tech to take a look at it, but try the unplug/reseat electrical connections fix first. Very sorry for your trouble. Hope this helped and best wishes.
Sep 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Engine codes
sometimes coming data,but the every error comunication,for the scannner
rpm up and down same the lightgauge,low high,codes u 1001 1000
Jan 15, 2009 | 2002 Nissan Altima
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
Mercedes-Benz 2000 S430 Logo
69 people viewed this question
Top Mercedes-Benz GPS Experts
D. E. Hev
steveOKC
Level 1 Expert
Are you a Mercedes-Benz GPS Expert? Answer questions, earn points and help others
