Question about Welding Tools
I just bought a airco 3A model 300 amp heli welder its needs a whole new power cord.how do I find the exact cord that will part up with it.
    Top Expert:
  • 10,875 Answers
Posted on Apr 27, 2015
  • 5 more comments
  • Shane Stump
    Shane Stump Apr 27, 2015
    Ok cool thanks
  • Shane Stump
    Are those welders 3 phase
  •  johnny rebel
    johnny rebel Apr 27, 2015
    they must be,check the manual,i didnt read it
  • Shane Stump
    Shane Stump Apr 28, 2015
    I can't seem to find the part in the manual
  •  johnny rebel
    johnny rebel Apr 28, 2015
    if i were you,i would research tig welders and how they work,,BEFORE YOU ATTEMPT TO HOOK ONE UP!!,if you would know anything about welders is that you use the biggest wire that is allowed for the amperage you are using ,you dont need a diagram to find out the wire item number,you are going to burn somebodies house down,now,i read that whole file that i gave you and i found what you were looking for,i will post pictures for you,,you may understand that a little better,remember,,JUST BECAUSE THEE SHALL OWN A WELDER DOESNOT MAKE A WELDER OUT OF THEE!
  • Shane Stump
    thanks.. weres the pucs
  • Shane Stump
    pics
  • 2,210 Answers
Look carefully at the outer jacket of the current cable, there is usually a spec printed or moulded on it every few inches / mm. If not take a sample to a supplier of cable and have it matched. The owners handbook should give you this as well. Check the company website for a tech phone number.
  • Shane Stump
    There wasn't a power cable at all.
3 Suggested Answers
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
  • 5603 Answers
SOURCE: how do I build a barrel switch?
You probably want a "tap switch" rather than a barrel switch.
Here is a site to give ideas:
http://www.romanmfg.com/products_switch.html
Posted on Sep 11, 2009
Manuals for my airco Hornet 200 Special model # 6WD20AG-1A
try going google and typing in-- workshop ( or user if that is what you want) manual for hornet welder model 6wd20ag-1a welder ---
if there is one available as pdf then download it
Oct 29, 2016 | Welding Tools
What size fuse dose my airco welders wasp take
power fuse would be 10 amp as that is the capacity of the power leads into the machine.
Aug 01, 2015 | Welding Tools
I need a manual for a airco welder. Stock number1341-0266. Serial number hk220507. Thank you.
This was made by Miller. It is the same as a Miller Dialarc 250 ac/dc.. Go to www.millerwelds.com, then "service", then "owners manuals" then "search", and scroll down until you find the dialarc.
Apr 22, 2015 | Welding Tools
How many AMPS should the Charger be for a Jazzy Select Power Chair
3A should be fine. Pride uses 3A for other models with two U1 batteries. Make sure they're wheelchair batteries: gel or AGM. Not car batteries.
Aug 20, 2014 | Health & Beauty
I have an Airco Mini Pro 125. It will not feed wire. I have checked everything. Power going to the motor is running 6.5 to 13 VDC and I'm getting 8 amps. I pulled the moter and it works fine on and 12v...
I had the same problem. The transistor had lost one of the legs in the socket. With no luck figuring out what the transistor was I managed to solder a wire to the little stub left on the transistor and wired it around the socket. Good luck
Mar 06, 2011 | Welding Tools
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
Clarke MIG welder parts??
what model is your clarke? i have a 125en which is the exact same welder as a craftsman, you could probably get a new feed motor or other parts for the welder itself from sears, the gun is a tweco style gun same as lincolns, so if you need tips or anything you can get those just about anywhere welder stuff is sold. i hope i helped.
Apr 09, 2009 | Clarke Power Products Welding Tools
Welding Tools Logo
158 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
