Question about Vacuums
Can the battery be damaged to have it on charge for too long
  • Vacuums Master
  • 932 Answers
Gerard,
Some manufacturers build in what they call a trickle charge and when you charge the battery, once it reaches full charge or almost full charge, it goes into the trickle mode and only charges enough to keep the battery at full level. Best thing would be to consult your owners manual and follow their directions. Also, so that we can better help you, please include the make and model of the equipment you are referring to. Hope this helps!
Posted on Apr 28, 2015
Of course. So charge it depends on the limited time of your battery.
Posted on Apr 27, 2015
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
charger."
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
I have a Dyson DC35. It has just stopped working. The green light on the charger is on and the vacuum is plugged into the charger, but it is like the vacuum is completely dead.
I had a similar problem. I have it on the wall mount and it turns out the plug that goes into the dyson to charge the battery had become unseated from the mount. I pushed it back in ("click") and that fixed it.
Mar 18, 2012 | Dyson Vacuums
After I press clean, my irobot works for about 5 minutes than stops and everything goes out, includiing lights on the robot, and i have to manually put it on the charger. Would I be right in thinking that...
possible your battery has a damage allready need for replacement. but try to fully charge your battery then after test it if it a minutes that use the problem happens againyour battery has damage.
Feb 23, 2011 | iRobot 53501 Roomba 500 Series Vacuum...
I noticed my run time was getting shorter and shorter, within the first 6 months. I checked my charger and base with a V.O.M. okay. About 4.4 volts on the base about 14 volts on the direct line. I bought...
To extend Roomba's battery life and keep Roomba cleaning at peak performance: • Always keep Roomba plugged in when not in use. • Recharge Roomba as soon as possible. Waiting several days to recharge Roomba can damage the battery. • For storage off the charger, remove the battery from Roomba and store in a cool, dry place. • Blue or black batteries should be stored after Roomba has been used. • Yellow batteries should be stored after being fully charged.
16-Hour Refresh Charge If Roomba has been left off the charger for an extended period, Roomba will initiate a special 16-hour charge cycle. This extensive charge refreshes Roomba's battery and extends the battery life. While charging, Roomba's "Clean" button will pulse quickly. Note: For best results, do not interrupt this Refresh Charge.
Happy Holidays The FixYa Team
Dec 18, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Plugged in the charger to my model AV-701B electric broom after not using for a few months. Charging lamp went green as soon as I plugged it in. Unplugged the unit but it will not turn on.
The same happened to me. The battery will no longer take a charge. Oreck store was of no help. Do NOT buy the new model it is poorly designed. you can find other brands in the same category at half the price and much better brands for about the same price.
rudy
Oct 08, 2010 | Oreck ElectrikBroom AV-701B Handheld...
Rechargable batteries need to be replaced
you may not need batteries just a new charging plug. if the batteries are damaged all you need to do is replace the handheld part of the pronto, this is where the batteries are located.
Jul 09, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
My romba doesn't keep it's charge very long
This happens over time as the battery wears out. Time to replace the battery. Or, perhaps the battery is not receiving a full charge when it needs to (and damage has been done). Power supply might be culprit of not receiving full charge.
Nov 06, 2009 | Roomba Pro Elite Bagless Robotic Vacuum
Battery temperature sensor.
you should not make your own battery and use it with roomba, or try charging it with a charger not meant for roomba, i suggest you buy the APS battery on ebay for $30 - $40. and buy a new charger from the company for $30. You can do some serious damage to the motherboard on the robot and your roomba might not work at all after that.
Mar 10, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
