Question about Masonry Tools
Need owners manual to change knives - Masonry Tools
Re Saeco Magic Comfort+ coffee maker - machine notes that there are no beans in chamber when there are, and the grinding mechanism runs at about half the usual sound. I've removed the screws and clean
If the machine at some predetermined time is not filled with ground coffee a volumetric container it stops.
1. Check if the knives rotating.
2. Look if the ground coffee falls in grup while it is milling. If you left the volumetric tank open.
3.Maybe the knives mechanism is not at the right possition.
Nov 14, 2014 | Saeco Coffee Makers & Espresso Machines
My Singer Serger won't cut, I have changed the knives but it didn't help.
Perhaps the knives have been put in wrongly, check your manual.
Oct 12, 2014 | Sewing Machines
Which knives do I need to have a full set of kitchen knives?
Actually it is much simple than it sounds, you will only need 4 types of knives to have a complete set of kitchen knives. You need a chef's knife a paring knife a filleting knife and a cleaver, that's about it. You can perform almost any cooking task there is in the kitchen with those 4 knives.
Jul 25, 2012 | Camping, Backpacking & Hiking
Looking foe owners or users manual for just acquired Delta Jointer
If it's a newer model you'll be able to find exploded parts diagrams and user manuals here.
Otherwise, check the Delta publications section at this site. Bear in mind you might be able to download a copy of a similar model's manual that will provide most of the information you need for proper use and adjustment of yours. Otherwise consult the many fine reference books available that include sections on proper tune up and adjustment of jointers, from places like Fine Woodworking, Taunton Press, etc. etc. They'll have the basic information about changing knives, adjusting and shimming tables, etc.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Mar 26, 2011 | Delta Machinery Masonry Tools
Unfortunately i don't have the manual and i need to change the blades on a McAllister Planer Thicknesser COD305P. Can anyone help?
I can help, but you'll need the gauge to set the knives exactly in the same spot on both or all 3. Do you have the tools that came with it? Do you have new knives or are you getting those sharpened? Getting then out is no problem, just take note of how they sit in the cutter head, loosen the jib screws, don't touch the set screws, take out all the knives, clean the jib off and the blow out the cutter head, sharpen the knives or get the new ones ready to go in, put the jib in, lay the knife on it, tighten up each end just snug, take your setting tool and just scrape the top on the knife, do not touch it, move it or stop on it, just shave it slightly, adjust it so it is just right, tap it back in with a piece of wood if you pull it up too far, do the other side the same, then snug up the jib screws, check the depth again, It has to be the same left and right, all knives, otherwise you will get chatter marks and speed bumps in your wood. Once it is set, tighten up all the jib screws, then tighten them again, do the other knives, all the same, do not answer the fone, get them all tight, put on the cutter guard, and plug it back in. You should be all set.
Jan 02, 2011 | Masonry Tools
How do I change the two blades
Operator's manual for 22-547 portable planer is here.
Page 10 and 11 discusses the process of changing the knives in detail. I'd like to reiterate the manual's comment about how sharp these knives are. Use gloves or be VERY careful.
Per manual:
1. DISCONNECT THE TOOL FROM THE POWER SOURCE.
2. Lower the head assembly by turning handle (B) Fig. 15.
3 Remove chip deflector (A) Fig. 19.
4. Carefully place knife setting gage (B) Fig. 20, on the cutterhead so the rounded sections are directly over the knife as shown.
5. Loosen the knife locking bar by turning the seven knife locking screws, six of which are shown at (C) Fig. 21, CLOCKWISE and carefully remove knife locking bar (D) Fig. 22, knife (E), and springs (not shown) which are located under the knife.
6. Remove the remaining knife in the same manner.
7. Thoroughly clean the knife slots, knife locking bars and screws. Check the screws. If the threads appear worn or stripped or if the heads are damaged, replace them.
8. Carefully replace the springs (not shown), knives (E) Fig. 22, and knife locking bars (D), into both slots of cutterhead (F). IMPORTANT: WHEN REPLACING KNIFE LOCKING BARS (D) AGAINST KNIVES (E), AS SHOWN IN THE CROSS-SECTIONAL ILLUSTRATION Fig. 22, MAKE CERTAIN THE BARS ARE INSTALLED AS SHOWN, WITH
SCREWS (C), POSITIONED AT THE TOP OF KNIFE LOCKING BARS (D), AND ANGLED DOWNWARD HOLDING THE KNIVES (E) PROPERLY INSIDE THE CUTTERHEAD SLOTS. TURN KNIFE LOCKING SCREWS, ONE OF WHICH IS SHOWN AT (C), COUNTERCLOCKWISE JUST ENOUGH TO HOLD BOTH KNIVES (E) IN THE CUTTERHEAD (F).
9. Adjust both knives (see manual).
Jan 17, 2010 | Delta 22 - 547 12" Steel Knife Set for 22...
It seems to be cutting unevenly from left to right?
Operator's manual for the 22-547 is here.
It sounds like you may need to adjust the knives. Page 10 and 11 of the operator's manual discuss the details. See below: (I have removede references to the figure and diagrams in the manual - look there for pictures).
ADJUSTING KNIVES
To check and adjust the knives, proceed as follows:
3. Remove chip deflector
4. Carefully place knife setting gage, on the cutterhead so the rounded sections are directly over the knife as shown. When adjusted correctly, the knife should just contact the bottom of the center portion at each end of gage. Check the other knife in the same manner.
5. If an adjustment to one or both knives is necessary, slightly loosen the seven locking screws, by turning the screws CLOCKWISE into the knife locking bar just enough to relieve stress in the cutterhead and not disturb the knife setting.
6. With setting gage, in place, apply pressure to the knife being reset. Turn the seven knife locking screws, CLOCKWISE until the knife locking bar becomes loose. Lift springs will automatically raise the knife until it comes in contact with gage. Snug the knife locking bar by lightly turning the seven locking screws, COUNTERCLOCKWISE.
IMPORTANT: AT THIS TIME, ONLY TIGHTEN THE KNIFE LOCKING BAR JUST ENOUGH TO HOLD THE KNIFE IN POSITON INSIDE THE CUTTERHEAD SLOT.
7. If the other knife needs adjustment, repeat STEP 6.
8. After both knives are positioned in the cutterhead, turn each of the seven screws, COUNTERCLOCKWISE until the knife is secure in the cutterhead. NOTE: When tightening knife locking screws, tighten the end screws first, then inward toward the center of the cutterhead.
9. Replace chip deflector.
Jan 12, 2010 | Delta 22 - 547 12" Steel Knife Set for 22...
Is there a part for a delta Planer 22.540 to connect to a dust collector?
If there is you would find it at Dewaltservicenet.com and in the middle of the page under manual type in your model number for a schematic and owners manual for the tool.
Sep 27, 2009 | Delta 22 - 547 12" Steel Knife Set for 22...
Need info about circa1950's Rockwell/Delta 8" jointer
I can't help you with the knives, but I can help you with the motor - you need to find the plate on the motor with its specs. If it has a horsepower rating, just replace with the same horsepower. If it doesn't show a horsepower rating, I need the amperage (FLA), and the voltage, I can determine it from that. Please get back to me with both the horsepower rating and the voltage and FLA if you can, and tell me what voltage you are going to hook up to.
Mar 16, 2009 | Masonry Tools
Masonry Tools Logo
582 people viewed this question
Top Masonry Tools Experts
ray gallant
Tom Chichester
Are you a Masonry Tool Expert? Answer questions, earn points and help others
