Question about Poulan Garden
What size do i need to buy for the poulan riding lawn mower
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
What size what?
Posted on May 28, 2015
ken_howard
  • 10 Answers
SOURCE: starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Posted on Apr 25, 2009
  • 17 Answers
SOURCE: how to wire the solenoid on riding lawn mower
The large red cable from the battery should go to the large terminal on one side of the solenoid. The opposite side of the battery solenoid connection goes to the starter So now you have a heavy cable going from the battery to one side of the solenoid and another heavy cable (red) going to the starter connection. There should also be a small wire coming from the ignition switch to the small terminal on solenoid. If there are two small terminals on solenoid, ground the other one. To test the ignition switch, just turn the key and see if you get 12 volts, then you know that part is good. If not, check your ignition switch. So, back to the solenoid-----. If there are two small solenoid terminals with nuts for wires on the solenoid then the wires could be mixed up. So just reverse the two small wires and try again.
You would think they would make things easy and say on the solenoid, Battery connection here, and Starter connection here, and ignition switch wire here, but no, just nothing for the most part.
So now remember this is nothing more than a lightswitch type of a mechanism where instead of using your finger to flick the switch, we are using a small electric charge to momentarily close the light switch, in this case the starter motor, same idea.
Posted on Sep 21, 2009
  • 430 Answers
SOURCE: how to change oil in poulan 500 lawn mower
First remove the spark plug wire from the spark plug. Then tilt the handles down to the ground. It helps to have something you can slide the handles under or otherwise hold them down. Underneath the mower deck there will be a drain plug. You are in front of the unit facing it the drain plug will be at about 7-o'clock a few inches from the cranckshaft. It will have a square hole in it. Use an extension on a 3/8ths drive ratchet in the square hole and remove the plug. Be careful not to cut yourself on the blade, I usually remove the blade first and sharpen it while the oil is draining. Loosening the dipstick from the tube on top will help it drain faster. When its done draining replace the plug and reinstall the blade if it was removed. Then refill from the dipstick tube. The unit will take approx. 22 ounces of oil. Do not overfill.
Posted on Jan 04, 2010
SOURCE: Poulan 500ex riding mower 22hp 48
I have a 3 year old Poulan Pro 500EX, 46" cut lawn tractor. I stopped to put gas in and restarted the engine, but the lawn tractor won't move forward when drive pedal is depressed.
The engine loads up like the brake is on, but I checked brake and it is not engaged. Any ideas? All reponses greatly appreciated.
Posted on Aug 29, 2010
SOURCE: RIDING LAWN MOWER STUCK IN GEAR
My Poulon riding lawn mower will not move when I put it into gear, and I found a 1 or 1.5 inch thin metal square shaped rod under my mower on the ground, could this be part of the problem
Posted on Oct 07, 2013
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
Fuse diagram for poulan model: po17542lt size of fuse and the location of fuse
20 amp automotive-type plug-in fuse. The fuse holder is located behind the dash.
Feb 12, 2015 | Husqvarna Outdoor Poulan PO17542LT Lawn...
WHAT SIZE DRIVE BELT I NEED FO 30" RIDING LAW MOWER ? MODEL NO P01230lt SERAL NO.011310A001123 model no PO12530lt 12.5 HP
We do not have any info on this site
Just a chat room
Take you info to a small equipment
dealer/repair shop & they can look it up
for you
Jul 06, 2014 | Poulan Pro Lawn Tractor 2006 and Newer...
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan pro 300ex riding lawn mower
pull the top cover and see if the starter gear broke if so napa has them for about $10
May 06, 2012 | Garden
Need to fine out if it would what other size of belt you can use on 38 inch cut on poulan riding lawn mower
Are you asking what size belt to use or are you asking what other size belt, like you want to use one a little smaller or a little larger? If that is the case, what difficulty are you having that you would need to do that? Did you put a Craftsman deck on a Poulan or something odd like that?
Aug 06, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a woodsman 1800 and need the fuel line part number... looks like maybe 1/16 in line?
Cut a small piece of the line off, then measure the entire line. Take your sample and go to a car parts store and buy twice as much as you need. There are just a few sizes of fuel line and on lawn mowers there is no high pressure fuel line. No sense tossing a bunch of money away on fuel line with Poulan written on it.
Aug 21, 2010 | Poulan Garden
The star mounts on my poulan 42'' riding lawn mower
Without knowing your mower for sure, I think I know what you may need to do. Most often, you just need to remove the block that the pattern is on. These are most often bolted onto the shaft. If you don't have your parts book for your mower, you may bee able to look it up online.
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Need lawn mower manual
here's a link to the poulan lawn mower manual that you asked for http://www.oscar-wilson.com/MANUALS/AYP/HD145H42A.PDF have a good day and please rate this post.
Mar 19, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
59 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
