Question about GE Washing Machines
What diameter is drain line hose for GE model DDP1280GAWAD
    Genius:
  • GE Master
  • 1,585 Answers
Buy a universal hose carrogated
Posted on Apr 27, 2015
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: drain hose on GE washer clogged with sand
Hi, It is easiest if you have a wet/dry vac and **** the water out of the tub. You can also try and **** the water out of the drain hose and hope the plug is small enough that it breaks lose. The most common place the hose gets plugged is where it narrows after the pump going out the back of the washer.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
Bosch washing machine leaks
what size is the line you are using for the gray water. what i mean is if you are trying ti use the same size hose as the original discharge
hose, the pressure to high. the hose original was about 1 inch diameter, the hose use to go up than the hose hook shape goes into the drain pipe thats 2-3 inches diameter for draining the water went into the sewer system, if your trying to use 1-1/2 hose, the diameter not enough air or room for all that water. i dont think the lenth the issue its the diameter and amount of pressure that being forced down small hose or pvc pipe.
Oct 06, 2015 | Bosch Washing Machines
Would like to have 10 ft water supply and drains hose assembly. Is something like that availalble ?
Yes. Two ways to do it. I would use burst proof hoses first of all (the stainless braided style) I have seen lengths to 12' or couple 2 6 foot hoses with a threaded hose coupling. The drain hose is availible to any cut length at Home Depot or Lowes. Does not have to be the corregated plastic one , but one that is more kink proof the soft vinyl hose. Measure the ID (Inside diameter) to match up. Make sure you support the drain hose over that long distance since the drain water may weigh it down. Good luck!
Jun 22, 2010 | GE WSKS2060WWH Top Load Washer
Washing machine will not drain
Hi
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting Fixya.com
Oct 11, 2009 | GE Spacemaker Washer and Dryer Electric...
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Drain hose on GE washer clogged with sand
Vic
May 31, 2009 | GE WDSR2080D Top Load Washer
Water overflows from drain pipe
2 ins is rather small and there may also be a partial blockage somewhere in the system you are not aware off.
a naughty cure is to restrict the drain hose of the machine so water comes out a bit slower
Sep 05, 2008 | GE WBSR3140DW Top Load Washer
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
Older Portable Dishwasher
the bigger hose is the drain hose smaller one is the fill hose you can also look the model no. up on line like sears.com and order the hose assembly that has both hoses and the end hooks to the faucet
Mar 03, 2008 | Dishwashers
Standing Water in Dishwaaser
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Sep 15, 2007 | GE 24 in. GSD4060JSS Built-in Dishwasher
Dishwasher will not drain
I hav an Americana / GE dishwasher, only one and a half years old. the dishwasher is not draining. When I turn the selection knob on the front to wash, is begins filling with water again. But, the cycle is not actually working. I removed the drain hose from the disposal unit and allowed the really really nasty collection of water to drain out. I have a feeling that the hose connection to the washer is clogged. Is this possible. If so, should I remove the hose from the connection at the dishwasher and clean the hose or could it be something else.
Thank you,
Aug 31, 2007 | GE 24 in. GSD4320Z Built-in Dishwasher
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
