Question about Sony DSC-W690 Cyber-Shot Digital Camera - Black
When I cut the camera on , the screen says "Turn the power off and on again" . I do this and the message is still there and I cant take pictures.
  • 512 Answers
SOURCE: error message, cant take pictures
Camera needs to be serviced. This is a common problem with sony cameras. If you have any knowledge of electronic, you could take apart and clean and lube lens. If not sony will fix for a fee, go to the sony web site, they offer a repair service. This happened to mine, it cost $95 plus shipping costs to repair. Now it works great, for how long who knows.
Posted on Jul 17, 2009
  • 109 Answers
SOURCE: message turn power off and on again
your lens may be jamed thats why it tells you to turn off then on its tring to cycle the lens so i would check that first! good luck!
Posted on Sep 02, 2009
  • 11967 Answers
SOURCE: "TURN THE POWER OFF AND ON AGAIN"
This may be a lens problem. Try these... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 02, 2010
  • 1382 Answers
SOURCE: camera has a message coming up on screen sayng to turn camera off
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you!!
Posted on Jul 18, 2010
lock123
  • 6831 Answers
SOURCE: turn the power off and on again displayed
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
I have a p41 and on the screen appear "turn the power off and on again" so i turn it off and back on again but the sign is still there. i turn it off and on again and again but it is still there....
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Setup 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Aug 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
My Cyber Shot DSC W55 when i open it the lens keeps moving forward and backward and then something shows on the screen which says First "ACCESS" then the next one is "Turn The power off and...
Error: TURN THE POWER OFF AND ON AGAIN or Access is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 24, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
When I turn my camera on, the screen remains black and says turn power off and on. Upon doing so, when i turn it on again, it begins beeping and says turn power off and on. But if I go to the view pictures...
Turn on the camera.
To reset the Camera back to factory default, press the RESET button located above the PHOTO button which will change all settings back to factory default. The images and videos will not get deleted.
Jan 30, 2010 | Sony Cyber-shot DSC-M2 Digital Camera
Error message, cant take pictures
Jul 17, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Black screen
Turn the power off and on again message is displayed when the Lens mechanism is stuck or when there is an internal malfunction. To resolve the issue, try turning off and on the power for few times. If the issue persists, try power resetting the Camera.
To power reset the Camera, remove the battery from the Camera. Press and hold the power button of the Camera for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery to check the operation.
You can also try Initializing the Camera by selecting the INITIALIZE option from the SETUP1 Menu of the Camera.
Thanks for using FixYa
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Turn the power off and on again displayed
Well, I can not really believe it, but I had the exact same problem as you and that idea ACTUALLY worked. Smacking the sides against the palm of your hand does seem to work quite well. Thanks!
Jun 16, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Not functioning at all..need immediate help
Try the Panasonic web site technical support team. But if it is more than a year or so old- replacement may be the only option because of lack of spares.
Jun 12, 2007 | Panasonic Lumix DMC-LC50 Digital Camera
Sony DSC-W690 Cyber-Shot Digital Camera - Black Logo
43 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
