Question about Garden
How to change the oil on the pump
Model 020397
  • Rich May 01, 2015
    Hi Chrisabel Rocha, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 1,169 Answers
It does help if the Brand was posted. Would have found it if it wasn't for Google search.
Briggs and Stratton 020397-0 (Snapper 020397)
You don't normally change the oil in the pressure pump except when serving the pump. As for the engine it is same as any other Briggs horizontal engine. Some of the newer engine are now requiring oil to be pumped out to change it.
Posted on May 01, 2015
My toyota avanza was mixing oil and water then we changed the gasket and the oil pump, now we hv put in the oil then now it doesnt take the oil to the cylinder head what could be wrong
I am not familiar with working on this particular make/model but others I have done I usually prime the oil pump before installation. Other than that, if the oil pump is in the sump, make sure the gasket between the pump body and the engine is good otherwise the pump will be sucking air. Cheers
Oct 09, 2017 | Toyota Cars & Trucks
Changed fuel pump oil pressure keeps going to 0 put in new oil sensor same oil pressure no problem before pump
Jeff, you or somebody else will have to hook up a external oil pressure Gage and verify oil pressure OK, before you have a catastrophic engine failure.
Feb 29, 2016 | Cars & Trucks
Change the oil pump in a f-150 4.6 2002 model
Ford F150 5.4L Timing Chains and Guides Oil Pan Oil Pump ...
? 5:08
https://www.youtube.com/watch?v=BgvGjfzrRjU
May 10, 2014 - Uploaded by dezertol
Ford F150 5.4L Timing Chains and Guides, Oil Pan, Oil Pump, Cam ... i am looking into changing the oil pump myself... did you try removing the intake ... I need help with my timing for i 3v4.6 mustang gt, im about to take of my ...
Ford 4.6L, 5.4L, 6.8L Engines -Melling Oil Pumps - YouTube
Nov 04, 2015 | Cars & Trucks
Hi there, I have a Peugeot 207 1.6xs manual gearbox 2008 model and I recently replaiced the oil pump and filter and as I was driving back home from Peugeot pinetown, the vehicle displayed a fault which...
Worn main and rod bearings on the crank shaft. This is what creates the oil pressure. When the get worn they start loosing pressure. Also when the oil gets hot, it gets thinner, causing more lose of pressure.
Feb 07, 2015 | Peugeot Cars & Trucks
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
May 06, 2014 | Honda Garden
Broken oil pump need to change
Why, why, why do people expect a decent answer if they do not give complete information, in this case MODEL YEAR?
In 1999, there was a change over from the Evolution engine to the Twin Cam engine.
This resulted in a total change of the oil pump.
Up through the Evo, the oil pump was mounted to the outside back end of the motor case, and could be remove - reinstalled/replaced fairly easy.
Starting with the Twin Cam, the oil pump was completely redesigned and move to inside the engine, so you have to go inside to change,
Either way, beings as the oil pump could be considered the "Heart" of the Harley's circulation system, you should know what you're doing if you plan on tackling this yourself.
Dec 07, 2013 | Harley Davidson FLHTCUI Electra Glide...
Oil pump removal oil pressure
I need to know what year model Sportster you're working on. I know the book says you can change the oil pump without removal of the engine from the frame but it ain't that easy. Let me know exactly what year model you're working on. You may NOT have to pull the pump.
Are you certain you have no oil pressure? Pull the spark plugs and remove the oil filter. Spin the engine with the starter and see if oil pumps out of the oil pump adaptor. If it does, you have oil pressure and the oil pressure switch is lying to you. If your bike is equipped with an Evolution engine, 1986 or later, it will have hydraulic tappets. If you indeed do not have any oil pressure, the tappest will rattle badly.
Good Luck
Steve
Oct 24, 2010 | 1979 Harley Davidson XLH 1000 Sportster
My oil light is blinking in mhy 1998 Passat. Can you tell me what this may be?
I would check the oil level ASAP.In addition if you're vehicle is due for an oil change, git R done. I would then road test to see if the problem has ceased. Hope this helps
Apr 03, 2009 | 1998 Volkswagen Passat
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
