Question about Garden
Mower blows heavy blue/white smoke at random.engine stutters stops after idling a bit then does it again rounds later
    Top Expert:
  • 10,875 Answers
Overfilled oil
Posted on Apr 28, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Which engine ???
Kohler ???
Briggs ???
oil over full, water in gas tank, bad gas in gas tank,
can you say head gasket ???
When i mow a hill or thick grass it will blow white smoke and then it will quit
The mower decides how much fuel to use depending upon rpm. When it hits a tough patch rpm goes down and the throttle opens up. In this case the throttle opens too far and the engine floods producing the white smoke. The plug is temporarily fouled out and the engine quits. After the gas evaporates the plug will operate normally again.
Aug 21, 2014 | Garden
What happened to cause the engine on a Snapper riding mower to emit white smoke?
maybe low on oil, black smoke is when theres oil in the muffler, could be a blown headgasket, pistion rings could be fried also
Jun 01, 2014 | Snapper Garden
Excessive white smoke out of blow by
Just letting you know that white is water, blue is oil and black is gas coming out of the exhaust.
Jul 20, 2017 | Cars & Trucks
Car starts ok will idle but when you go to drive over 1500 revs car stutters and blows out clean smoke (fule not oil)
Does it overheat at all?
White smoke? or Dark grey smoke?
Could be Oxygen sensor (grey) or head gasket (white).
Jul 09, 2010 | 1999 Nissan Pathfinder
Ford Thunderbird 96 V6 3.8 Idle rough, smokes like big Diesel motor
CHECK ENGINE COMPRESSION.SOUND LIKE YOU HAVE WORN ENGINE VALVES AND PISTON RINGS AND VALVE SEALS IF ENGINE SMOKING BLUE.IF YOU ARE GETTING HEAVY WHITE SMOKE.YOU HAVE A BLOWN HEAD GASKET.WHEN DOING COMPRESSION TEST IF COMPRESSION READINGS 90 - 80 WORN RINGS 60 - 40 BLOWED HEAD GASKET.
Aug 29, 2009 | 1996 Ford Thunderbird LX
White smoke
White smoke is most likely cause there is to much in the engine.. Only takes about half quart.. Clean with degreaser and garden hose on the outside..
Jul 04, 2009 | Garden
14.5hp B&S ohv looses powes & blows white smoke on riding mower
This engine has a badly designed combustion head that causes premature failure of the head gasket. The removal of the overhead cam and head is relatively easy with the engine mounted on the mower. Just remove the hood before you begin. I had the same problem, same symptoms (white oil smoke, mostly when turning or on an inclide-=left side downhill) after the second season of mowing. Made me mad when I got it apart and saw the incredibly stupid head design. Replaced the head gasket and am into my second season with the new head gasket with no more problems but I expect it to blow again at some point. Poor engine design. Easily fixed.
Apr 01, 2009 | Garden
Car engine throws out thick smoke
look for problem injectors and leaking injector seals
May 09, 2017 | Dodge Neon Cars & Trucks
Black smoke from exhaust
hi nishga
im dave; hope i can help
First you need to determine if it is actually black smoke or if it is blue smoke. There are three colors of smoke that can come from the tailpipe. It is not white smoke obviously because that is easily differentiated from blue or black and generally indicates water or antifreeze leaking past the head gasket and into the compression area of the motor. White smoke is the steam of the water/antifreeze being emitted
Blue smoke is caused by engine oil entering the cylinder area and being burned along with the fuel air mixture. As with white smoke, just a small drop of oil leaking into the cylinder can produce blue smoke out the tailpipe. Blue smoke is more likely in older or higher mileage vehicles than newer cars with fewer miles. The car has many seals, gaskets, and o-rings that are designed to keep the engine oil from entering the cylinder, and one of them has failed. If too much oil leaks into the cylinder and fouls the spark plugs, it will cause a misfire(engine miss) in that cylinder, and the spark plug will have to be replaced or cleaned of the oil. Using thicker weight engine oil or an oil additive designed to reduce oil leaks might help reduce the amount of oil leaking into the cylinder.
Black smoke is caused by excess fuel that has entered the cylinder area and cannot be completely burned. Another term for excess fuel is "running rich". Poor fuel mileage is also a common complaint when black smoke comes out of the tailpipe. Black smoke out the tailpipe is the least cause for alarm. Excess fuel will usually effect engine performance, reduce fuel economy, and produce a heavy fuel odour in the engine compartment. Some of the causes of excess fuel are a carburetor that is out of adjustment which is not likely unless you have installed an aftermarket carburated system on your non-carburated car, a faulty fuel pump, a leaky fuel injector, or a faulty engine computer or emissions sensor. If black smoke is present, check the engine oil to make sure excess fuel has not contaminated it. Do not start the engine if a heavy, raw fuel smell can be detected in the engine oil. Check the above mentioned systems and after detecting the trouble replace the faulty parts and then the engine oil and filter.
Jul 20, 2008 | 1996 Pontiac Firebird
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
