Question about HP Photosmart M632 Digital Camera
What causes popping when m632 photosmart camera is turned on
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
2 Suggested Answers
SOURCE: I need a manual for my hp photosmart M632
NEED A MANUAL FOR MY HP PHOTOSMART M632
rmillam@att.net
Posted on Mar 28, 2011
Can I charge my HP 632 (that has rechargeable batteries in it; from the USB hooked to a solar charger?
You may recharge the batteries using any compatible charger. It doesn't matter to the camera whether the charger is powered by a nuclear reactor or a hamster running in a wheel. Bear in mind that the HP M632 is NOT a battery charger. The batteries must be recharged outside the camera.
Dec 12, 2012 | HP Photosmart M632 Digital Camera
Isn't establishing a connection to my computer
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 04, 2011 | HP Photosmart M632 Digital Camera
rmillam@att.net
Nov 01, 2010 | HP Photosmart M632 Digital Camera
My m632 hp photosmart just keeps saying establishing connection when plugged in to my pc
Having gone over five months without a response, I assume my suggestion to use a card reader solved the problem.
Oct 11, 2010 | HP Photosmart M632 Digital Camera
MY CAMERA TURNS ON BUT DOESN'T WORK
You haven't given me much to work with, so I'll have to take an educate guess. it 's probably a stuck lens mechanism, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the HP service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Sep 25, 2010 | HP Photosmart M632 Digital Camera
Hp 433 When I put In card Unsupported card pop's up
Hi! You may just want to reformat the card first before putting it in the camera. Sometimes its a system failure that causes this. Hope this helps and thank you for using FixYa!
Aug 20, 2010 | HP Photosmart 433 Digital Camera
SD card keeps popping up when inserted in cama. SD card will not stay down in camara Says it needs to be formatted. It will not format. Never has this problem before How can I fix this
The SD slot of the camera got damage somehow. The SD slot contains thin copper prongs that locks the card in place and comes in contact with the surface of the card. If these prongs are damaged, then it cause a read failure of the camera.
Sep 29, 2008 | HP Photosmart M525 Digital Camera
HP Photosmart m415 Power Trouble
Did the camera ever get wet? It seems that the connection from the battery to the device is weak. Check the battery compartment for corrosion, which can be caused by humidity as well. Also feel if the metal connectors are tight. If all seems well, you will have to take it in for repair.
Oct 26, 2007 | HP Photosmart M415 Digital Camera
HP Photosmart M632 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
