Question about HP Photosmart M632 Digital Camera
When batteries are placed in camera and the on button is pressed the camera comes on but starts popping.
Buttons locking
If taking the battery out for at least 15 minutes, pressing the power button without the battery in the camera, and then after you put
the battery in the camera doesn't work to fix a problem you can reset the camera to factory settings like this:
  1. Press the "Menu" button. Press the right arrow once to highlight the "Setup" menu.
  2. Press the down arrow five times to select "Reset All." Press the "Set" button.
  3. Press the right arrow button once to select "OK." Press "Set."
Apr 06, 2014 | Canon G12 Digital Camera
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Where do you put 3 AA batteries in the Disney Pix Click Wizards of Waverly Place digital camera? I can only find location to put 2 AA... and camera will not work.
  • They all seem to go in the same place. - some only seem to use two - this one uses three
The camera is powered by 3 AA batteries. Only use the battery specified by the manufacturer.
  1. Lift the rubber USB interface cover on the bottom of the camera and gently press the lever to the left.
  2. Lift the faceplate off completely and place it to the side of the camera.
  3. Insert the batteries using the battery polarity symbols (+/-) as a guide.
  4. Replace the faceplate by gently placing it back on the camera body.
  5. Replace the rubber USB cable connection cover on the bottom of the camera.
  6. Turn the camera on by pressing the Power button. To turn the camera off, press the Power button again.
  7. Note: If the camera is not used for one minute, it will automatically shut down. To restart the camera, press the Power button.
Apr 12, 2010 | Disney Pix Click Digital Camera
Fujifilm A345 keeps saying zoom error lens wont open and when i press shutter button it makes a short buzzing sound then zoom error comes up help
I recently came into this camera and after a day of testing it, it's doing the same thing. My work around is this. When it's on I press the zoom function and the lens then pops out. Then after it's out, I remove the batteries while it's still on. Put the batteries back in, and power it on (lens will be popped out) and then it starts working. I only paid $7 for it at a good will. So I was taking a chance it worked somewhat. This may work for you temporarily. Not sure how long this one will last.
Oct 11, 2009 | Fuji FinePix A345 Digital Camera
When I press the power button the light turns
hi..
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
thank u
rate me!!
Jul 15, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Sanyo VPC-E760
The USB cord does NOT charge this camera, you have to take the battery OUT and place in in the charger that comes with the camera. If you do not have a charger, you can buy one on-line for about $20.00
Oct 30, 2008 | Sanyo VPC-E760 Digital Camera
FinePix A350 Power Button stays down after being starting camera
This just plain shouldn't happen. Call Fuji while your warranty is in effect, and have them fix or replace it.
Mar 23, 2008 | Fuji FinePix A350 Digital Camera
Camera Won't Turn On
I have bought many "broken" Casio cameras that had this issue. 9 out of 10 were easily fixed.
The first thing you do is remove the battery and card. Let the camera sit empty overnight. Next morning, take the camera and puch down on the power button...the on and off button. Hold it for 15 seconds. Release it after that 15 seconds. This will reset the camera. Then try the battery and card again. Many times...that is all it takes.
If that doesn't do it...but a new battery (NP 20) they sell on Ebay...no more than $7 as rule with shipping. Buy a new charger as well...no more than $8 usually..same place. Do not throw away your camera or take it in for repairs until you at least try this. It could be the cheapest fix possible.
If a new and charged battery still doesn't work, it may be the connection points...inside the camera...the little springs you see when you look into the battery slot. I have never had to adjust these as they were never the problem. What is sometimes the problem, id when the battery is pushed into place...the right way and not backwards (we have ALL done it!) there is a little latch that comes out from the side to hold the battery in...make sure it does in fact hold the battery in tight before shutting the battery cover. The battery cover does not have to be closed for the battery to work.
If all the above fails...sell me the camera and charger and battery...seriously!!
Dec 05, 2007 | Casio Exilim EX-S600 Digital Camera
HP Photosmart M632 Digital Camera Logo
37 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
