Question about Health & Beauty
TGA Buddy Mobility Scooter?
Help, when you pull the forward lever, it does nothing and the battery lights are not on even though the batteries are fully charged. Really, really need this for work. Can anyone give advice?
  • 1,263 Answers
Hi, I can help you okay but you must give me more info,,
the plug that goes from the frame that inserts into the steering column, is it loose ? this is the battery lead ...
Regards
Rob
www.gewizrepairs.co.uk
Posted on Jul 10, 2015
patemi
  • 366 Answers
SOURCE: I have a toshiba laptop,
Change your AC charger.
It's NOT charging "When the laptop is plugged into the AC, the power meter in windows tells me that the power source is still batteries, and the battery level drops by about 1% every few hours"
That's the reason why: "battery has completely died"
If you do not change it you'll continue to "still it gives me the same low battery indication and will not turn on. "
Posted on Jan 04, 2009
EmotionLess
  • 52 Answers
SOURCE: I have a flashing/blinking orange battery light.
Most likely you have a problem with the battery or electric circut in your laptop. Unfortunatly there is not much you can do, except taking it professional repair service.
Posted on Mar 19, 2009
gewiz
  • 1263 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
  • 220 Answers
SOURCE: bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
Posted on Jun 30, 2009
proton77
  • 1183 Answers
SOURCE: My dell precision m65 battery does not get charged
If your battery is not charging there could be two reasons for the same . First the battery has exceeded its lifetime and requires a change or is faulty
Second your ac adapter is not giving enough charge to charge the battery.
Open the battery health meter , by pressing the Fn+ F3 key on the keyboard . check if battery reports any error message.
Shutdown the computer and disonnect the Ac adapter and the battery and press the power button for 10 seconds
Reconnect both the Ac adapter and the battery
power on the system and tap on the f2 key slowly on the left side of the screen , look for the option that says battery info.
Check what is the status of the Ac adapter and is the battery showing charging.
if the Ac adpater shows as none, then adapter needs a replacement otherwise the battery.
Thanks for using fixya
proton
Posted on Aug 15, 2009
TGA Mystere mobility scooter. Scooter drives perfectly but drains batteries within 5 minutes of driving. Have tested with brand new batteries but still does the same. Help!
Hi again ring TGA PARTS FOR A PRICE ON CONTROL BOX 0117 329 1740 good luck i think u need to check THE BATTERIES condition buy a BATTERY LOAD TESTER .OF E/BAY COST APROX ,$35 ,.THIS WILL GIVE U A TRUE READING ON THERE CONDITION,,. Cheers
Dec 27, 2016 | Health & Beauty
Why won't my mobility scooter go?
Three things you might try:
1. Make sure the charging cable is not plugged into the battery pack.
2. Make sure the transaxle is engaged. Try changing the position of the manual freewheel lever.
3. The "horn" also gives diagnostic codes. See if there is a repeating pattern to the beeps and compare them to the code chart.
Sep 19, 2014 | Pride Go Go Elite Traveller Plus HD 4...
Scooter won't move when forward/reverse engaged.
http://mobility123.com/help-fix-mobility-scooter-powerchair/
Engage the freewheel lever
- allows you to operate the mobility equipment with the standard controls.
Disengage the freewheel lever - This unlocks the unit and allows the wheels to spin freely. You can easy push the equipment without power. This is especially helpful if you run out of battery power and need assistance.
Apr 21, 2017 | Health & Beauty
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
May 21, 2014 | Pride New Mobility Legend 4 Wheel Scooter
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Batteries say fully charged on charger but only 1 red flashing light and the green
Hi okay if the red light is flashing , make sure you not in freewheel mode, it could be that the batteries are low , leave on charge for about 4 hours and test again.
Make sure the connector plug that fits from the frame to the handlebars is a good fit, this supplies power to the controller.
Regards
Dec 13, 2012 | Health & Beauty
When I switch my mobility scooter on lights etc all work but no drive
hi, I first suggust you make sure that Freewheel is disengaged,
to test this try to push the scooter forward if it moves forward move the lever ,
Check the Wigwam or throttle controls to make sure they are not loose,
Check for reset switches under the seat or on the steering stem,
Check for car type fuses under the seat.
Jul 23, 2009 | Pride Victory 4 Wheel Mid-Size Electric...
Health & Beauty Logo
52 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
