Question about Whirlpool Duet Sport WFW8300SW 3.4 cu. ft. Front Load Washer
Got a f -22 code ordered and replaced lock mechanism as instructed still does not work sounds like is not locking to start washing process now
    Genius:
  • Whirlpool Master
  • 1,585 Answers
Could b door striker
Posted on Apr 27, 2015
For the last few weeks, my 5 year old LG 2487HRMA, has been giving me de code errors shortly after starting. It is because the lock light just goes from red to off for no reason.
Lift up the top of your washer and there will be a code and test sheet in there that will help lead you to fixing that problem, almost sounds like it went into the its own test mode.
Jan 09, 2016 | LG WM2487H Front Load Washer
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Locking assembly does not lock and i replaced the assembly the coil in the lock burned up. note there is a f-22 code on the mashine
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will tryto lock it six times before displaying the error code.
Possible Causes/Procedure ? Door lock mechanism is broken or removed from door.
? Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lockunit and Central Control Unit (CCU).
Since you replaced the lock assembly, I would check all the wiring connections on the CCU. What is your model number?
Jul 20, 2011 | Washing Machines
I have several problems with my Whirlpool washing machine AWO 12763: 1 .- For a long time do not make spin until we press the door. 2 .- For the past few weeks, when entering water, says suddenly we...
Hi.
F-22 is door lock error. The door lock was already defective and now has failed completely. You need to replace the door lock.
Here the error explained in detail:
F22
DOOR LOCK ERROR
Theme Door Lock message is prompted when the door cannot be locked. The CCU (central control unit) will try to lock the door six times before displaying the F 22 error code.
Possible Causes:
The door lock mechanism is broken or removed from door.
Repair Procedure:
3. Check the wire harness connections to the door switch/lock, and the central control unit.
Regards.
Ginko
Jun 04, 2011 | Washing Machines
Door will not lock and code on panel reads"F" then
f the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
I added the instructions in the image below on how to remove and replace the door lock mechanism. NOTE: Disconnect the power cord from the power source before removing and replacing the door lock assembly.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open has a code 22
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The door is locked after the wash cycle. The machine stopped, gave a code F-22 and will not unlock.
Possible cause , door lock mechanism is broken or removed from door. Unplug unit , then check harness connection to the door switch/lock unit and the central control unit(CCU)
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door latch to Kenmore Elite Oasis gas dryer has come loose. It will not close properly in order for dryer to start. Need instructions on how to repair or replace latch piece on door.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washer is not locking the door it sounds two clicks and is showing the leter in scream DE what is that means
HI. This is a Door Open error code.
Here are 4 reasons for this issue:
* The Door may not be all the way closed
* Loose electrical connections at door switch and pwb assembly.
* Door switch assembly is out of order
* Gasket on door may be creased in
Ok. You have stated that the unit is attempting to lock the door, but it is not locking. There are two click, then the error code illuminates the DE code. This is common when the control cannot initiate a door lock sequence. The cause will be a failed door lock mechanism, and it will require you to replace this mechanism asap, if possible. The actuator has failed. Replacing the door switch mechanism, will correct this issue.
Oct 19, 2009 | LG WM-2277HW Front Load Washer
Whirlpool Duet Sport WFW8300SW 3.4 cu. ft. Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
