Question about Kenneth Cole KC3915 Watch
What is the correct replacement battery? - Kenneth Cole KC3915 Watch
How do you change the battery in a reizen talking watch it is radio controlled white face with black numbers
  • Remove back
  • Find battery. Note mounting arrangement for later.
  • Identify battery type
  • Obtain replacement battery
  • Remove old battery
  • Install new battery with correct polarity
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your watch to a jeweler who, for a reasonable sum, will handle replacement.
Take TTTT
Dec 02, 2016 | Reizen Watches
Fossil fs4141 battery size
  • Remove back
  • Find battery location. Note mounting arrangement for later new battery installation
  • Identify battery type (not size)
  • Install in correct position with correct polarity
  • Check operation
  • Install back
  • Set time, etc.
Sep 12, 2016 | Fossil Watches
How to replace battery in Skagen 585XLTMXB watch ?
  • Remove back
  • Find battery and identify type. Note mounting arrangement
  • Obtain replacement of correct type
  • Remove old battery. Install new battery
  • Check operation
  • Install back
Aug 09, 2016 | Skagen Watches
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
BRegards
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
Need correct replacement battery
the watch movement deters which battery the watch needs it is very important you do not put a battery in that doesn't suit the watch as it can short out the circuit however you can get the correct size in a gold seal quality which should not leak, also the older the watch, the more demanding the watch becomes on the battery as the movement components start to experience wear and tear
Apr 16, 2014 | Wenger Swiss Military Alpine Diver...
HOW DO YOU REPLACE A BATTERY ON A CASIO 1572 A168
This is how I replaced the battery on my Casio 1572 A168 watch.
1- Undo the 4 screws to remove the back cover. Note the correct orientation for reassembly by observing the writing.
2- Gently pry out the mechanism.
3- Undo the 6 clips round the circumference of the mechanism with a pin or watchmakers screwdriver. The top half should come loose. There is also a 7th clip which can be more easily unclipped from underneath. Replace the battery.
4- Note the correct position of the small spring. This spring is necessary to make the watch speaker work.
5- Note from the picture the correct position of the special contact which connects with the lower board. If this does not connect properly then the display will disappear.
6- With the battery in place, the watch display should work properly. If there is a problem try connecting the two all clear contacts with a screwdriver, paper clip or small piece of wire to reset the watch.
7- Reassemble the watch and make sure the rubber seal is in place. The seal on my watch was slightly deformed so I used a very small amount of silicone sealant on the tip of a screwdriver to tack it down properly.
8- Put on the back cover being careful not to overtighten the 4 screws and damage the threads. The cover needs to be positioned correctly and not 180 degrees in reverse so the spring will connect with the correct place. When you look at the front and back of the watch the writing should be the same way round.
Kind regards
Chris
*Looking at the picture it might also be possible to replace the battery by removing just the one clip that is closer to the spring. However I found that that clip is more easily undone from underneath, so I preferred to do a more complete dismantling. This also gives more freedom to reposition the battery.
Feb 26, 2013 | Casio A168W Wrist Watch
What is the correct battery for my freestyle model 750
The manufacturer does no recommend that you replace batteries yourself (presumably to ensure that it retains the waterp.roof seal)
See excerpt from their web site support.
"Do not attempt to repair the watch yourself. It is strongly recommended that a certified jeweler, watch repair technician or Freestyle service center replace your battery. This will help in preventing water leakage from improper battery replacement, which is not covered in your warranty. "
Dec 27, 2009 | Freestyle Shark Buzz Wrist Watch
I just repaced my casio watch batteries but i'm
This may sound dumb but make sure the battery is in the correct side up. There should be a + or - symbol on top of the metal piece that snaps over the battery. If that's correct get a pair of tweezers and spread them open, and touch one side to the top of the battery and the other side down inside a little hole with ac marked beside it. That will reset the watch, and your display should come on.
Feb 28, 2009 | Casio G3011 Duplex LCD Watch
Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Kenneth Cole KC3915 Watch Logo
60 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
