Question about Welding Tools
My Millermatic 230v wire feed welder shut off during use and will not turn back on ?
    Problem Solver:
  • 12 Answers
Usually, when you reach the duty cycle, you will get wire feed without any arc. You really don't define "shut off". Does that mean you turn the welder on an the fan runs, but whem you pull the trigger nothing happens? Or does that mean when you turn the machine on it does absolutely nothing, like it isn't even plugged into the wall? The more you tell us the easier it is to help....
Posted on May 01, 2015
    Top Expert:
  • 45,569 Answers
If you use the welder for too long at high amps it will go into over heat mode and shut down
you may have to reset the overload control ( how to do is in the user manual)
mig welders need a cooling of period during use and it is stated in the duty cycle specifics for the machine
contact the service shop for exact details
Posted on Apr 27, 2015
I have a millermatic 175 it is new the over temp light is on . what could be wrong. and no wire feed.
You bought this brand ne from a merchant?
Take it back.
The over heat light is when you have welded too long and it shuts down to cool off; were you welding?No wire feed is too vauge; you looked at feed motor and the wheels aren't moving?
https://www.youtube.com/watch?v=ophtUI7RbmU
Sep 12, 2016 | Welding Tools
I can turn the welder on and it can run all day but when I start welding with in a minute the overheat light will come on and it will stop feading wire. I'm trying to weld on mid temperature.
Have you checked so see if your power cable is the right size?? Is it a 220 or 110? If it is 110 then it will cut off after it gets hot, if it is 220 and the power cord is too small then the machine will be trying to pull more amps than the cord can handle causing it to overheat and shut off.. My husband has been a welder for 20 years.. I'm just passing along what he suggested might be the problem.. Hope this helps!
Oct 03, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
New welder, only fed wire a couple times now it wont work
the noise you hear is the relay for the wire feed,it means that your tension on the wire needs to be set,tighten it if it is too loose and loosen it if the roller on the feed is moving but the wire is not,also,make sure the wire moves easily in the handle,always keep your cords straight so they dont bind.
May 05, 2015 | Millermatic 212 907405 Auto-Set Mig Welder...
Millermatic 350p help code 0
check the rectifier by the fan housing make sure it is not back feeding
Jul 07, 2014 | Miller Welding Tools
Our MillerMatic 175 wire feed cannot be adjusted down enough. The rheostat seems to function, but even the lowest setting is now way too fast.
Your Millermatic 175 has syncronize wire speed-voltage feature in order to reduce the wire speed first reduce your heat (voltage). Try again.
If this was useful to you please vote. thanks.
Feb 10, 2011 | Miller MATIC 180 MIG w/cart/AND SPOOLMATE...
Millermatic 200 will not weld
1 - Check the ground connection to the work, including the actual cable to clamp connection.
2 - Make sure that the wire feed rollers are nice and clean. The wire needs to be clean too.
3 - Check that the polarity changing wire connections are nice and tight, clean, etc.
4 - change and or service the contact tip at the end of the gun.
as always, gently clean out the loose junk inside the case. A clean welder is a happy welder. :-)
Nov 16, 2008 | Welding Tools
Welding Tools Logo
209 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
