Question about Hunter Dryers
Remote clicks when I push reverse, but then clicks again and goes back to reverse blowing or turning
    Genius:
  • Hunter Master
  • 1,617 Answers
You might need a new receiver. Call Hunter @ 1-888-830-1326
Posted on Apr 29, 2015
I turn car on cranks fine no throttle /acceleration gas pedal goes to floor no response in park drive neutral or reverse . ESP sensor is on I have tried to push button and disconnect battery.
Whatever you do dont push the pedal to th floor on fuel injected motors, you will do nothing but harm to your vehicle very dangerous as each time you mash pedal to floor gas will dump in the intake, and lay at the bottom and not burn time and time again till one time you blow out your intake, never push the pedal down and turn key on fuel injection, crbed motors are different than injected motors, hope this helps.
Feb 29, 2016 | Mercedes C-Class Exterior Pillar Posts...
New Bright, F-150, Red Thunder 4X4: Truck goes into "static" mode when forward or reverse is pushed on remote. In other words, truck starts up when turned on, steering, horn and lock work fine,...
Get new battery, I have 4 batteries, all will turn it on, get horn lights, sound. 2 do the exact same thing yours is doing, 1 runs about 5 min then starts into your problem, 1 is good and will run for about 20 mins.
Aug 27, 2011 | New Bright Ford F150 Rc
I am programming an RCA Universal Remote (Model #RCR311W) and looking for the four digit Brand Code for a Dynex 22" HDTV (Model #Model: DX-22L150A11).
Hello
RCA universal remote codes for Dynex Tv are:
11463, 11810, 12184
To use this universal remote with your home entertainment
system, first you need to program it to control your devices.
There are four ways you can program the universal remote to
operate your devices:
• The Auto Code Search goes automatically through all the
codes for the device you're trying to control. It's the easiest
method, but it can sometimes take longer than some of the
other programming methods.
• The Brand Code Search searches through the codes for
select brands of devices. It's not as easy as the auto code
search, but it can be faster.
• The Direct Code Entry lets you enter a code from the
accompanying code list for your brand of device. It's not as
easy as the other methods, but it's potentially the fastest
method.
• The Manual Code Search lets you manually go through
all the codes for the device you're trying to control
Auto Code Search
codes for the device you're trying to control. When you find
the one that operates your device, you can stop the search and
store that code.
1. Manually turn on the device you
want to control.
2. Press and hold the device key you want to program. While
you're holding down the device key, use your other hand
to press and hold the remote's ON•OFF key at the same
time.
3. Wait until the ON•OFF key comes on and stays on. Then
release both keys.
4. Point the remote directly at the
front panel of the device you
want to control. Press PLAY on
the remote and wait 5 seconds.
The remote is testing a batch of
10 codes on your device.
Did your device turn off?
YES: Go to step 5.
NO: Press PLAY again. The remote tests the next batch of
10 codes.
Keep pressing PLAY every 5 seconds until your device
turns off.
5. When your device turns off, press
the REVERSE key on the remote
and wait at least 2 seconds.
The remote tries the last of the
previous ten codes.
Did your device turn on?
YES: Press the STOP key. You're
done! You've programmed this
device key.
NO: Press REVERSE again. The remote tests the next
code in the batch.
Keep pressing REVERSE every 2 seconds until your device
turns back on. When it does, press STOP.
Note: If you accidentally press the REVERSE key after your
device turns on, press the FORWARD key. Then, wait two
seconds to see if your device turns off again.
ok
Jan 16, 2011 | Televison & Video
Fan goes in reverse instead of pushing air down it goes counter clockwise. How do i reverse it?
1.) this model uses a remote control controller to operate its functions
2.) the reversing is done via that remote.
3.) the link is wireless
4.) do you have the remote?
Apr 28, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Philips 42fd9954-175 Plasma won't power up
Failing capacitors in the power supply have now failed completely.
Had never tried blow-drier as a TV service tool.
Heat changes the resistance of many parts, especially dying capacitors. Heat also causes parts to expand, such that cracked solder connections are closed up.
Oct 21, 2009 | Philips 42FD9954 42 in. Plasma HDTV
My TV goes black with no picture but it has sound.
Sounds like the unit maybe running hot . Try reversing your vacuum so that it blows rather than **** and blown the unit out.
Oct 08, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Fuse replaced but blows againwhen remote clicked for CT32SL14
This is a problem with the main poiwer supply. It could be simply a shorted rectifier diode or more complex. Without taking measurements inside the set or at least seeing what the condition is of the board, there is little we can do to help. This unit shoul dbe brought to a service shop with a request for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair. Expect to pay $50 or more for the estimate.
Dan
Aug 20, 2009 | Panasonic Televison & Video
Code Search
First try this method as it is the quickest way,
To program a component using the Automatic Code Search method, perform the following steps:
1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button.
aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Only use the codes below if the auto code search dosen't work. Codes program a zenith tv are below
Zenith 1000, 1001, 1004, 1051, 1083, 1151, 1152,
1154, 1217
You can click the link below you will be able download the manual.
http://support.rcaaccessories.com/main.html?topicid=216&Referring%20DeviceDocID%20List%20Index=1&navtypeid=16&pagetypeid=35&prevPageIndex=13&selectedmodel=RCR450&selectedFamily=generic
Mar 15, 2008 | RCA RCR450 Remote Control
Lightware vp800
blow out the dust, check the fans, and then replace the thermo sensor if necessary
Sep 08, 2007 | Office Equipment & Supplies
Dryers Logo
67 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
