Question about Vacuums
How to know when brushes need replacing - Vacuums
  • Anonymous Apr 28, 2015
    I was asking about the brushes on a 2 hp motor pet hair dryer.
  • Vacuums Master
  • 932 Answers
If you are talking about the brush that picks up debris off of your carpet, one way is to see how soft the bristles have become. I work on Oreck vacuums a lot and as they age they will get very soft and they will also get shorter as they are used. Most of the vacuums that I work on will present the problems of getting shorter and that is when you would replace them. One way that you could check is to take a flat ruler or some other piece of hard, flat material and lay it across the brush opening and turn the brush by hand and see if any of the bristles stick up beyond your ruler. If they do not, then you need to replace the brush. Hope this helps!
Posted on Apr 28, 2015
New brush &all is clean, yet still telling me to clean brush
no idea as we do not know what you have try the manufacturer
Jan 15, 2017 | Vacuums
Why are the brushes not spinning?
Hi Liz, if your brushes are still in good shape and do not need replacing then I would see if something else isn't broken or busted. You can always check for an obstruction in the brushes or remove the brush assembly & then reseat the brush assembly. Before doing so you should remove both Tanks from your Hoover. Then there are two buttons on top of the Nozzle Assembly that holds the brushes. You will need to release these two buttons on top, then tilt the handle of the unit backwards and this should let the brush assemble fall out of place. Inspect the brush assembly for any obstruction and even check to see if all the brushes still spin okay. If all looks good then align the post on top of the brush assembly with the hole on the bottom of the nozzle assembly and then snap the brush assembly back into place. I know this might sound crazy but did you first check to make sure that you did not have the switch set to "Wet\Dry Pickup." This will stop the brushes from turning as the switch needs to be in the other position to turn.
Aug 11, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Dyson DC14 reset button location
go to http://content.dyson.com/support/?basketTotal=0.00&basketQty=0&logged=false
proceed with your models, and see videos or troubleshooting or video for to se the reset button.
God bless you
Aug 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
Brushes in motor are arcing badly and motor only occasionally will start. How do i remove the motor brushes for replacement. (from the green plastic case)
This is kinda of tricky. need to know what kinda of vacuum it is first. However if you get it apart. To fix this problem the armeture brass needs to be cleaned & you should replace both carbon brushes. Should be cheap to fix if you are up to it. good luck save some $$$$...
Nov 10, 2009 | Vacuums
Roller brush of my dyson dc07 isn't turning...
it migh be the belt.check your belt or it is the brushroll is stuck.(from to much hair ect.)
Jun 29, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 brush roller is worn and won't make contact with the carpet anymore. I need to replace the brush roller but don't know how...HELP?
Buy the brush over the web etc..
To take the brush out
1 - Take the outer covering - uese a penny to turn the yellow srews
2 - Slide the black brush out from the assembly - Try the non belt side first.
3- Slide the belt out of the brush.
4 - Take brush out - Replace it with new one.
May 09, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Bissell Velocity Vacuum brushes stopped
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
http://www.bissell.com/Products/p/CleanView+Brush/product.aspx
http://www.bissell.com/Products/ak/replacementparts/p/CVPT+II/product.aspx?%23=Detail#Detail
http://www.bissell.com/images/UserGuides/35934_804.pdf
Mar 29, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
I need a "Bearing Assembly" for roller brush 61445-1,I Have a GE 106575
Probably should just go to a repair shop and they should be able to order one for you, that is if they are available by themselfs. Or if you have a store where you live that sells vacuum parts, you could go there.
Dec 08, 2007 | GE 106585 Upright Vacuum
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
