Question about Dryers
The outlets stopped working . Try flipping the breaker still no electricity from outlets
  • 3,960 Answers
You need to call an electrician. There may be a problem in the power panel itself.
Posted on Apr 27, 2015
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
Nuvo Essentia won't power up
First, try unplugging all of the sound system and plugging the amplifier into an outlet on a circuit that was not changed by the electrical work. Also, plug an outlet tester into the outlet you were using for the amplifier to make sure it is correctly wired. If one outlet in a system has hot and neutral reversed and others don't, this could cause problems with some designs.
If you are lucky, dirty power from sparking inside the circuit breaker crashed the control circuitry in the amp, and it just needs a hard reset (power disconnect/reconnect) to be made functional again. In the worst case, something got fried and you'll have to use instruments to track it down.
Apr 23, 2014 | Nuvo Essentia Amplifier
Wiring outdoor motion lights (with 14/2) to a nearby outlet (possibly 12/2)that has power. After wiring into outlet and turn on breaker, I lose power, but don't trip the breaker?
First take a cord and hook it to the motion lite and make shure it works .Remember that it only will work at night or dark area and you have to have lights in the fixture to make the contact.and make shure the plug is not on a dimmer or the wires are flipped. WHT. To the common side and black to the darker side and it has to be grounded .exspeacily if it is a led fixture.
Apr 01, 2017 | Cooper Wiring Devices Motion Sensing...
No volume on tv after purposely tripping circuit breaker
Try returning to the initial setup procedure in case some setting changed as a result of the power interruption.
Dec 09, 2013 | HP PL4272N 42 in. HDTV Plasma Television
Two of the electrical outlets in our kitchen have no power. I checked to make sure the connections were tight and they were, still no power. Then I replaced both of them with new receptacles (ones that...
Each outlet receives power from previous outlet box or switch box in a long chain of parallel wiring back to ceiling box, or junction box, and then back to circuit breaker.
Use process-of-elimination to find problem.
Locate all boxes on same circuit breaker. Locate box before the two dead boxes... it can be in ceiling light, or switch box, or outlet box. Then test those wires. Look for loose quick connect where wires are pushed into hole on back of device, or loose white wires twisted together and shoved to back of box.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-wire-switches.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 03, 2013 | Leviton 10 Brown Switch Outlet...
Oulets in home quick working
• One should inspect the Convenient Outlet first.
• Check the breakers on the Main Panel
• For electrical wirings check the Building Plan.
These should be done with a license electrician,
Supervise by an electrical engineer or master electrician.
and must conforms with National Building Code.
Aug 03, 2012 | Hammering
We flipped the breakers in our fuse box to do some wiring, when we flipped breakers back--our electric dryer will not start, but the light is on inside the dryer when I open the door
Hello- I would check the dryer outlet and confirm you are getting 220V. As well, flip the dryer breaker on an off again (it should be a double style breaker, 2 singles linked) sometimes they are sticky. Let me know if it still doesn't work. Best regards.
Sep 27, 2010 | Maytag Dryers
Ceiling fan just stopped working. Turned on
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
Jul 11, 2009 | House Brand Dryers
Not truning on
I would check your breakers again your oven breaker is a double one .. one of them may not be turned back on...
Apr 17, 2008 | Frigidaire FEF355 Electric Kitchen Range
Dryers Logo
51 people viewed this question
Top Dryers Experts
