Question about SkyCaddie GPS
I need phone number for skycaddie - SkyCaddie GPS
Why is it locked up?
How do I Reset My SkyCaddie If It Locks Up? - SkyGolf 360
clubsg.skygolf.com/.../6-6178-How_do_I_Reset_My_SkyCaddie_If_It_...
If your SkyCaddie is locked up you can reset it by following the instructions for your ...If you have a SkyCaddie Breeze or SGX you can reset these devices by .
Aug 11, 2015 | SkyCaddie GPS
Tip
Loss of GPS Signal and Yardages
It is often thought that a GPS device like the SkyCaddie should keep constant uninterrupted view and connection to the satellites, thus always giving accurate yardage information. This is true of cellular technology, indoors or out, etc, but not for a GPS device like the SkyCaddie. A clear, unobstructed view of the sky must always be maintained for optimum performance. Here are some other tips:
1. When going to play golf, the SkyCaddie should have a fully charged battery and should be allowed to search and acquire satellites for at least 10-15 minutes, prior to play. During this time, the device should be stationary. Many people power the device on then head straight to the course. From that point on, the yardage info you get may be off or may not show at all.
2. Is the golf course you are playing in need of an update? It's good to plug your SkyCaddie into your computer and allow it to sync with the SkyCaddie desktop software. You will receive updates to the device if you do this periodically and you can view your course list to see if any of your downloaded golf courses should need an update. An unupdated golf course on the device can cause yardage problems.
3. Placing the SkyCaddie in your pocket during the game, placing it in a golf cart cup holder, tall trees or heavy shrubbery, hilly terrain, very overcast cloudy days, etc., all can impede satellite acquisition and yardage accuracy.
4. Internal issues. Most SkyCaddie models may have an outward antennae view, but there is also an inward antennae connection that could be compromised. If this is true, the user will not know this, as this type of issue is internal and will need to be sent in to the company for repair, contact them to have this done. This can also be the source of why a device never seems to acquire satellites and/or give accurate yardage information.
on Aug 12, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
I can't get my skycaddie to move.It's like it's frozen
Hi Dorothy,
The first thing you should do is remove the battery. After replacing the battery make sure it is completely charged. After that, turn your skycaddie back on and it should work normally. Make sure that you are outside with an unobscured view of the sky. When you secure access to satellite your GPS should record your movements larger than 50 yards or less. I would use my phone to verify my exact location.
Cheers,
Dr. Bob
Jun 11, 2015 | SkyGolf SkyCaddie SGX GPS Receiver
When I turn on my skycaddie at the golf course or at home , I geta message, could not start Application
Are you sure you have registered the device with Skycaddie? If not theedsahe will continue to appear.
I would call them make sure you have all the information they will need on hand (model number, etc).
They are very helpful and can even download the course there and then to your device for you if it is not all ready loaded. Hope this helps.
Jan 15, 2015 | SkyGolf SkyCaddie Handheld GPS Unit
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
I tried to renew my skycaddy. I got on line but was told to download a update. which I did. Then as I proceded through the renewal it said to hit on the icon. Problem was the icon disappeared after the...
Did you download the courses of choice first before you tried to renew after applying the update?
If your membership has been renewed and the SkyCaddie still displays a renewal reminder, your renewal information was not successfully communicated to the SkyCaddie. To finalize the renewal process, please download the courses of your choice to the SkyCaddie from your Favorites list in CaddieSync. The download communicates your new expiration date to the SkyCaddie.
Jun 22, 2010 | SkyGolf SkyCaddie SG4 GPS Receiver
Cant get past personal info page to activate skycaddie golf range finder
Prior to activating your SkyCaddie, you will first need to install a simple software program to your Windows-compatible PC. This software program, referred to as SkyCaddie Desktop, will allow your SkyCaddie to communicate with the SkyGolf website. This program allows you to DirectConnect with the SkyGolf website, so you can personalize your SkyCaddie, download courses and periodically update your SkyCaddie’s software. NOTE: If your computer is protected by a firewall, it may need to be set up to allow our SkyCaddie software programs to access the web. If your firewall software displays any warning messages during the activation process, simply indicate that you wish to allow access. if the software is not installed the unit will not get activated Activating Your SkyCaddie Within 30 days, please register your SkyCaddie, create a “My SkyCaddie” online account and select a SkyPlayer Club Membership Plan by going to the SkyGolf website at www.skygolf.com. Click the “Getting Started” link for information and instructions to complete the process. During this process you will be asked to create a user name and password for your online account referred to as “My SkyCaddie”. The “My SkyCaddie” online account offers a full range of member services, easy access to download courses, support and more. In addition to creating an account, you will be asked to select a SkyPlayer Club Membership Plan that best fits your needs. click this link directly to get more details http://service.alan-electronics.de/golf-electronic/sky-caddie/SG-2-UserGuide.pdf check out on page number 8 of the link to get details on this isue. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 19, 2009 | GPS
GPS Logo
65 people viewed this question
Top SkyCaddie GPS Experts
Joseph Hoffmann
Lyle Siemens
Lyle Siemens
Are you a SkyCaddie GPS Expert? Answer questions, earn points and help others
