Question about Ovens
The time display has gone blank. When I switch on temp dial the red oven light flickers. When I switch on fan dial nothing happens
  • 30 Answers
Assure full power is available to the unit(220 volts-not 2 times the same 100 volts). Depending on the model, and age of the unit, the circuit board behind the clock is failing or has failed. The timer board directs timed power for the oven, shows the times, and may have other features. Any elements are usually directly controlled by the knobs without going thru the timer board. When the timer display disappears and stays blank no matter what you do, even turning the breaker off and then on again , then power thru the board has failed. This could be caused by mass failure of the board(burned out-burned parts-vaporized parts) right down to a couple simple components that have failed due to age and don't pass the power onto the circuit.. High voltage is present and any troubleshooting should be done by a competent person for that task. Be safe.
Posted on Apr 29, 2015
Instructions for a ignis electric oven as there is no temperature guide or modes on front of oven
I don't see what looks like your model anywhere, or a manual for any model, or a company website, so if no one can help you try this.
The left dial could be- bake, broil, fan, convection cook, now the bottom pan should come out so you can see the bake element.
Turn it one setting and see what happens, either broil (top),,, bake (bottom), convection fan (bottom), turn and wait to see what happens.
Right should be temp, not sure if the dial has a stop or you can spin, but it at 12:00, put at 6:00 I say this maybe 300deg F.
Get over temp gauge (cheap).
If you don't get any help, then you need to try and see what does what and mark it down.
If you can't see top burn, maybe top pan come out so you can see it.
They get red hot, so you can tell which one turn on.
Sorry, can't find any info.
Apr 01, 2013 | Ovens
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
Ge jkp15aa
Take the back off the control panel and see if you can access the board. If you can see the board component side, go to radio shack and fgget freeze spray. Start the oven and when it quits like you described, spray one part on the board at a time till it comes back on. OR buy a new board
Feb 07, 2013 | GE JKP15 Electric Single Oven
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
I have an AEG B6139 electric oven and the interior light and fan comes on but the oven will not heat up despite putting the setting on high. Next to the dial for the interior light and fan a small red...
Hi I am Vortash it sounds to me as if the oven element has blown you need to have it tested by an engineer .. he will check for continuity .. if it is open circuit then you will need to replace it .
I would hev thought that if the fuse had gone the oven would have no light or functions of any kind as the power would be off .. unless this model has an extra fuse fopr the element alone doubtful however it does have a heat sensor cut off above the oven that cuts off the element from the supply .. If you have no manual for this unit you will find one free to download from http://www.safemanuals.com .. regards Vortash
Apr 29, 2009 | AEG B3101-4 Electric Single Oven
Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Plz rate my solution.
Thanks
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
57 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
