The machine shut off during use and will not turn back on. The breaker and outlet have been tested "good"
  • Phil Lacy
    Phil Lacy Apr 27, 2015
    I said welding machine NOT washing machine never mind!!
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Also check door inter lock
Posted on Apr 27, 2015
  • 173 Answers
Sound as you have a bad connection. Does it show a fault code?
Check the board and verify connections. Make sure appliance is unplugged before touching any wires on the board.
How to reset brandt washing machine
Stopped or Won't Start If the washer won't start or has stopped during a load, verify it has power. Plug a nightlight or other device into the power outlet to test it if you can easily access it. Otherwise, check the circuit box for a tripped breaker. Open and close the lid or door of the machine. If the washer stopped during a wash, adjust the load so that it is balanced. Check if the drain hose is clogged, and clear if needed. Turn the machine on with dry hands. If it still won't start, unplug it or turn the circuit breaker off, then back on until the breaker firmly clicks in place and plug the machine into the outlet. Push the restart button. Some machines may require you set the knob to a specific setting for the reset feature to work. On some machines, hold down the button labeled "Start-Pause" or "Stop" for a slow count of five. Turn the washing machine on. Run a rinse and spin cycle to check that washer is working and that the error code, if applicable, cleared.
Washers Without a Reset Button If it isn't possible to access the washing machine's plug to manually reset the washer, turn off the circuit breaker. Leave it off from 30 seconds to 1 minute, depending on the machine model or instructions in the owner's manual. For washers with a knob control, turn the dial clockwise to any cycle other than "Final Spin." With button controls, select any cycle other than "Spin." Check that the water to the washing machine is on. Turn the breaker back on. Turn the washing machine on. Some machines require that you open and close the lid six times after plugging the machine in to reset the motor.
When Reset Doesn't Work In some cases, after using the reset button -- or resetting the washer manually -- nothing happens. Your machine may have a problem or a faulty part that keeps it from operating. Among the most common are problems with door switches, latches or a faulty timer that may require replacement. Authorized technicians can replace parts or service the washing machine as needed. Websites of major manufacturers have replacement parts available to order and some provide schematics or answer your questions. On a recent-model washing machine, check if it's still under warranty.
Aug 14, 2016 | Brandt Washing Machines
Start button wont respond.Ultra wash s/n 15801805808
Check to see if the electrical breaker is working for that circuit. Next check the outlet that the machine is plugged into (115Vac). If all is, so far, copescetic, Turn off the breaker and pull the control panel. Test the "button" with a multimeter. If it is solid state, turn the breaker back on and CAREFULLY test to see if there is voltage coming into the panel. If not, look for a blown fuse. If no blown fuse and voltage is there, replace control board! Good luck!
Dec 27, 2012 | Dishwashers
Breaker
1) test the c.breaker or blown fuse from home FIRST, and reset or repair call some electrician.
2) test the wall outlet for ground properly.
3) put some desk lamp is turn ON the circuit is o.k the fault is the machine otherwise the problem is the outlet home.
4) test the c.breaker or fuse in the machine, repair and reset.
5) test the power cord for open or break.
6) Do not use extension cord, eliminate.
7) see the block and proceed with logic sense, use the DVOM or VOM very important.
God bless you
Jul 11, 2012 | Exercise & Fitness
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Our tap leaked and water got into the electrical part of the machine which now will not turn on. We have allowed it to dry out, is there a switch we can flip to reset the circuit breaker?
Inside your breaker box usually its marked. If not check breakers to see if any are tripped. If non seem tripped your going to have to go one by one. Plug light into outlet to see if it works first. If it dont proceed to test each breaker individually. If it does light up than you have a problem with your washer not the outlet. Also if you have a meter to test the outlet to see if you are getting power. Please contact me back and let me know if the outlet has power. Also please include Make and model of washer also model number of washer. Thank you
Jul 18, 2011 | Washing Machines
The power is on but it won't run
Power issues with treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Thanks for the rating Good luck
Dec 22, 2010 | Exercise & Fitness
It does not turn on says safe
This message appears when you remove the Safety key.
Kindly provide me with the make and model of the machine?
Are you sure that the key is intact? Is it properly placed?
Thanks!!
Aug 21, 2010 | Exercise & Fitness
Maytag dryer
• Be sure the door is latched shut.
• Be sure the power cord is plugged into a live electrical outlet.
• Check the home’s circuit breaker and fuses.
• Press the START button again if the door is opened during the cycle.
If everything checks out ok with the above check list, you may have electrical motor issues. I would run a break point test on the motor and the control panel as well. (You will need a Voltage needle to perform a break point test.)
Feb 22, 2009 | Maytag LSE7806A Top Load Stacked...
Saeco Incanto will not power on.
The curcuit breaker on the boiler probably tripped. There are 2 of them on the boiler. You can remove the back cover to access these parts. If you are not comfortable with taking the machine apart, take it to a service center.
Check out www.CeriniCoffee.com
Authorized saeco service center for new york
Oct 25, 2007 | Saeco Incanto Classic Espresso Machine
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
