Question about GE Ovens
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
The stove has an external Stainless Steel oven's cover door with a glass which it is not exposed to the internal part of the oven. Seems like with the use of the oven the tape fatigued and the glass detached from the SS door frame. I reattached with regular double sided tape and worked for a couple of weeks but it detached again. It seems that the solution should be a heat resistance tape since regardless that the glass is on the outside is does get a bit warm. On the GE parts the door panel appeared as a an assembly and it does not detailed the tape use.
  • GE Master
  • 473 Answers
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Posted on May 03, 2015
SOURCE: replace doors on jenn air oven with stainless
It is possible but usually costs more than the oven is worth. Call Marcone appliance parts in St. Louis for pricing.
Posted on Jun 29, 2008
  • 116 Answers
SOURCE: GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Posted on Aug 31, 2008
onthejob5130
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
SOURCE: GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Posted on Jun 28, 2009
Where do you get the double sided tape to stick the glass door back on oven door?
Far as I know the glass oven door is sealed with special silicone putty that is resistant to a temperature of 300 Celsius .
Previously, the required perfect clean the surface with alcohol.
Dado
May 23, 2014 | Electrolux EOG9330 Gas Double Oven
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Need to glue outer cold glass door to the door frame.. in cadco convection oven
not sure which to use but id go to a window auto glass shop and inquire
Dec 12, 2012 | Cadco Ovens
How to remove door on stoves EL716 toop oven
I can only say for the 720. You have to remove the whole oven from the kitchen furniture and then unscrew/remove the top and side panels. You will then see the springs on either side of the door.
Important. Remove the inner glass panel from the door first, before you release the springs.
To remove the springs, ensure the door is closed and then unhook them. You then should be able to remove the door frame.
May 07, 2010 | Stoves 720EF Electric Double Oven
How do i take the door off to clean it
To take the door off you have to remove inner glass panels from both doors. Then remove the appliance from the housing unit. When the unit is out, you then have to unscrew the top panel and both side panels and lift them clear.
With the door closed, support it with one hand as you carefully unhook the large springs from the door hinge arms. The door frame can now be removed.
The above is from the handbook. You can actually remove the outer glass panel as well but personally would just slide the inner glass panel out and clean the door in situ.
Feb 06, 2010 | Stoves 720EF Electric Double Oven
GE glass top and oven are not heating?
I have an electric oven that is turning on but not heating up. The oven, broiler, & stove top are not heating up. Any easy solutions to this?
Jul 18, 2009 | GE Profile JKP18 Electric Single Oven
May 23, 2009 | GE Ovens
Broken inside glass of oven door
Most units use Torx screws to hold the door together from the inside. Open the door, use tape to restrain the inside of the door or get help. Remove the 4 screws and the then remove the panel. Should be easy from there.
Dec 06, 2007 | GE Profile JT952 Electric Double Oven
Neff u1721 fan door problem
yes it is a heat resistant adhesive and ive never had any success in regluing them
Nov 06, 2007 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
149 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
