Question about Ungo SR6000 2 Way Security with Remote Start Combo System
Car won't start
The key fob is draining the batteries that are being put in it within a day or two. When the battery does die, auto start won't work, but the car won't start, either. When the key is in the ignition and the car is attempted to be started, it doesn't turn on, but the lights on the dashboard blink on and off for a few seconds, then go off by themselves. The vehicle has to be left alone for an hour, even with a new battery before it starts. What is going on?
    Top Expert:
  • 2,907 Answers
Car Won't Start?
This procedure usually works:
·Check the battery cable connections:
Make sure the positive cable, makes a good connection at the battery and at the starter. Make sure the negative cable makes a good ground connection at the battery and (preferably) at the engine.
·Check the battery the simple way, like this:
Turn on the headlights, then try to start the car.If the headlights do not dim or go out, then the battery is likely ok.
·Check the starter and solenoid:
If the wiring looks ok, then look at the starter solenoid for a good connection, and proper voltage at the starter(10 volts minimum while cranking).
If the starter spins and no crank, the problem is most likely the Solenoid's pinion gear is stuck.
Have someone hit (not too hard) the starter while you try to start the car. This usually works by dislodging a stuck pinion gear.
·Make a simple test of the alternator:
If you can, somehow get the engine running, measure the voltage at the battery. It should be at least 13.6 volts to properly charge the battery.
Posted on Apr 27, 2015
Battery completely drained after 45 mins of listening to cd player without car running,
a healthy battery will take a charge and discharge and be o k -you have several things going on-the ticking noise is some kinda rely that is turning on and off probably because of low voltage-the voltage jumping around sound like the alternator is giving up and is not fully charging battery-you may also have a drain on the battery that doesn't stop when you turn the key off like an extra power amp for the radio- you can take your car to autozone or advanced auto and they will check out the charging system for free and tell you what is going on-cheers Denny
Nov 23, 2013 | Cadillac DeVille Cars & Trucks
Why does my 2004 BMW 525 intermittedly have no power?
IT DOES SOUND LIKE KEY FOB DYING AND I HOPE IT IS AS IT WOULD BE CHEAPEST PROBLEM TO SOLVE. GOOD LUCK
Apr 14, 2017 | 2004 BMW 525 i
My 2006 Chevy Malibu key fob just got programmed by the dealer and then it stopped working a month later. I went to the auto parts store and bought another battery cause my car said "fob battery...
my chevy malibu(2006) keeps stopping on me as if I turn the key off. I sit for a minute or two and it starts right up and runs fine. The panel lights don't come at this time..it just dies. Have replaced ignition mod. & put in new thermostat, better grade gas but it still stops. Any ideas?
Jul 12, 2011 | 2006 Chevrolet Malibu
The battery in my car keeps died, so I jump it then it dies again
if you have a multi meter disconnect positve battery terminal and put red wire to battery and black to battery cable put multi meter on resistance should be 0.005 or less if more then check for things that may be plugged in to cig lighter etc turn door lights off etc dont turn key on any more than 0.005 will drain battery
Aug 25, 2009 | Mercedes-Benz ML-Class Cars & Trucks
2003 remote key fob batteries keep draining
Is there a circuit board inside with soldered componets ? May have silver migration problem , they used solder without lead ! GM has same problem with instrument cluster draining the vehicle battery . Chevrolet Truck Battery Dies Overnight Part II Watch this video . You may want to ask these guy .
Apr 21, 2017 | 2003 Chevrolet Silverado 2500HD
1994 Dodge Viper will not start after storage and battery drain.
With the battery charger connected or a jumper battery simply click the alarm key fob on and then off. This will reset the alarm and the car should start...had mine towed to find this out
Apr 07, 2009 | 1994 Dodge Viper
HELP HELP !!!!!!! Electric fault i think !!!!!!!!!!
1....ensure the battery in the "Key Fob" is OK............Press either Lock or Unlock button for more than 1 second, the lamp on the fob will light if OK. Change battery if it does not illuminate! 2.....if battery on fob OK.......Re Syncronise the key fob to the car by:.... a brief press on either button twice and within 30 seconds turn Key to position 2 on the ignition lock
Hope that fixes it...let me know?
Nov 09, 2008 | 1998 Mercedes-Benz C-Class
Ungo SR6000 2 Way Security with Remote Start Combo System Logo
Top Buck Vehicle Parts & Accessories Experts
Craig Butler
Craig Butler
xxxxxx xxx
andy148814
Level 1 Expert
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
