Question about Xerox Phaser 3300MFPX - 30 PPM Multifunction Network Duplex Monochrome Laser Printer, 3300 MFPX, 3300-MFPX, 3300MFP/X, 3300/MFPX
My multifunctional xerox phaser 3300 paper fails main 126.c. What's the problem ? is the fuser ?. please help.
Only shows an error and does not work
  • JMJr May 07, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 208 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
  3. Scroll to Fuser, press Reset.
SOURCE: xerox phaser 6120 laser printer paper jam fuser
Fix, well i am a dentist in Marysville washington and just got this printer from a family member and same thing was going on.
I looks like paper stuck in the middle roller. I just got a small mirror and pair of dental tweezers and removed a lot of jammed paper. it works fine now but you need do go to the dental section in drug store, so you can see where the jam is at.
Posted on Oct 26, 2009
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
  • 2072 Answers
SOURCE: printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Posted on Mar 10, 2010
Where is the fuser door on a xerox fax machine 3300 mfp
The fuser door is at the back of the machine. Open the door, pull down and close firmly shut. If the error persists it could be that the sensor has gone bad. The sensor is actually hard wired to the High Voltage Power Supply that sits right above the paper tray underneath the machine. It would need to be replaced if closing door doesn't fix the error, the part number is 105N02120,a link to picture of the part is 105N02120 Xerox 3300MFP HVPS Item Inc
Sep 17, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Fuser module fails to warm up
Hi Anonymous,
I suspect your printer is quite new.
I think your Fuser unit to be at fault. You need to order a new spare fuser unit from Xerox or investigate further.
Good Luck.
Jun 14, 2014 | Xerox Phaser 3635MFP/X Multifunction...
I have a problem with the fusor xerox phaser 6125, the display say error 010-397 please help me
That is in fact a problem with the printers fuser, which melts the toner to the paper. You should replace the fuser (part# 675K65654). To replace it open the front door, and at the top right you should see a gray clip you push down and then slide the fuser out starting with the right. When installing the new fuser slide the left side in first and then the right. Iteminc.com has this part in stock and ships same day. Hope this helps, good luck. Thanks for using FixYa!
Aug 08, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
Phaser 6250 DP keeps on jamming at Fuser.
Paper type set correctly? Does the paper enter the fuser? If not, the fuser drive has failed, replacing the fuser may correct it.
Nov 19, 2010 | Xerox Phaser 6250DP Laser Printer
Engine fuser low heat error on my xerox phaser 3500
You will need to replace the fuser.
You may want to look and see if you just have a piece of paper wrapped around the roll, but most likely the heating element has gone bad or one of the thermistors have failed.
Call 1-800-835-6100 and tell them the model number, and if it is a 120 volt or 220 volt fuser.
Feb 10, 2010 | Xerox Phaser 3500/DN Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox Phaser 6250N Jam at Registration Roller
I use to have the same problem, but downloaded a fuser patch at the Xerox site:
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi?new,kb=Phaser_6250,company=%7B5AC8CA72-62D5-4658-8D6F-D2F393C98A63%7D,ts=xo,ques=ref%28security_level%29:1,ques=ref%28Country%29:45,/,case=R1001052703
if that link doesn't work, go to the Xerox site and look in the area:
Home > Support & Drivers > Phaser 6250 > Knowledge Base
ID: R1001052703Phaser 6250 Support Knowledge Base Jam at Registration Roller (code Jam RR)
Follow the instructions and hopefully your printer problem will be resolved.
Apr 18, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Mar 07, 2008 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 3300MFPX - 30 PPM Multifunction Network Duplex Monochrome Laser Printer, 3300 MFPX, 3300-MFPX, 3300MFP/X, 3300/MFPX Logo
80 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
