Question about Woodford Outside Water Faucet - Modular Box Model 30 Freezeless Wall Faucet
Trying to replace , but just keeps turning - Woodford Outside Water Faucet - Modular Box Model 30 Freezeless Wall Faucet
What should I try replacing next?
check for spark . if you have spark it should fire or at least try timing may have gone .
Mar 22, 2015 | 2002 GMC Sonoma
My phone wont go to my lock screen it keeps turning on over and over again
Try removing the battery, wait 30 seconds, and replace the battery.
Nov 04, 2014 | Boost Mobile Kyocera Hydro Smartphone
My Monitor LG Flatron W2243S keeps flickering and turns off, this started yesterday
Try another good monitor, if it solves the problem replace the monitor if not replace the computer.
Oct 25, 2012 | LG Flatron W2243SPF Widescreen LCD Monitor
When trying to start and wont turn over, car keeps trying to start after key off and key pulled out!!! starter???????? how hard is a starter to replace on 2000 corolla?
check your wires under the car at the starter. make sure that the wires arent damaged and stuck together. if they are fine replace your ignition switch. should come in 2 parts. replace the electrical portion. keep your key.
Dec 24, 2009 | Toyota Corolla Cars & Trucks
Have a brother mfc7440n and it keeps displaying "drum ending soon". have replaced the drum, but keep getting same display
You need to reset the drum counter.I'm not sure that working with your model but try it.
Try opening the front door cover and keep open. Then pressing clear, it should say replace drum, press 1 for yes, it should then say accepted, close cover and turn off.
Oct 08, 2009 | Brother Office Equipment & Supplies
Tv wil not turn on just keeps making a clicking noise
ur relay keep try hard to turn tv on that u hear clicking noise.
+5VDC is leaking! open back cover,check power supply board.
1000uF or 2200uF capacitor is popped open or leaky.replace with known top quality capacitor.do it ur self repair will save u $200.
Jul 07, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Trying to replace starter in a 95 ford taurus. i am afraid i will ruin the wires because they keep turning when i am turning the nut
take a board and put it under the starter and that will keep it from turning while you are taking the nuts off the wires.
Feb 25, 2009 | 1993 Ford Taurus
E.E.C fuse keeps blowing in 1991 Ford Explorer
sounds like you got a short try tracing harness to see if theres anything visible
May 26, 2008 | 1991 Ford Explorer
Television keeps turning itself off.
There are two integrated circuits called convergence amplifiers , they need to be replaced. this is a common failure on this model. the cost to replace with parts is around 250.00 dls depending on the tech. if you need more help let know thanks
Jun 14, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Woodford Outside Water Faucet - Modular Box Model 30 Freezeless Wall Faucet Logo
Top Woodford Plumbing Experts
Donni Steen
Tom Chichester
Are you a Woodford Plumbing Expert? Answer questions, earn points and help others
