Question about Lands Phones
Avaya 8410D Unable to transfer. We tried switching out his desk phone and it is still not working. The transfer button does appear to be acknowledged. Anyone experience this issue?
Here is the trace of the call 11:07:07 active station 25393 cid 0x1b18 11:07:29 hold target-music-source 1 station 25393 cid 0x1b18 11:07:29 hear moh port 01A07024 11:07:29 xoip options: fax:off modem:off tty:off (mus-igc) xoip ip: [10.4.109.40]:2068 11:07:29 xoip options: fax:off modem:off tty:off (mus-igc) xoip ip: [10.0.60.11]:54376 11:07:29 active station 25393 cid 0x1b76 11:07:30 dial 25232 11:07:30 ring station 25232 cid 0x1b76 11:07:35 active station 25232 cid 0x1b76 11:07:44 idle station 25393 cid 0x1b76 11:07:44 unhold station 25393 cid 0x1b18 11:07:45 conf/tran hold station 25393 cid 0x1b18 11:07:45 active station 25393 cid 0x1b97 11:07:45 hear moh port 01A07024 11:07:45 xoip options: fax:off modem:off tty:off (mus-igc) xoip ip: [10.4.109.40]:2050 11:07:45 xoip options: fax:off modem:off tty:off (mus-igc) xoip ip: [10.0.60.11]:54408 11:07:47 dial 25232 11:07:47 ring station 25232 cid 0x1b97 11:07:48 active station 25232 cid 0x1b97 11:07:49 idle station 25393 cid 0x1b97 11:07:52 active station 25393 cid 0x1ba0
I need to know how to transfer a call into someone's voicemail on the Avaya 8410D.
hit the transfer button ,dial the extension of the other user and hit transfer again . or hit transfer and dial the voicemail extension and dial the voicemail extension of the other party and hit transfer
Apr 18, 2011 | Avaya Definity 8410D Phone
How do you transfer a avaya phone to another phone
You cant use this phone on a regular analog network, with out additional hardware. Unless, you put in a simcard who provide the service to transfer calls.
Nov 05, 2010 | Avaya Definity 8410D Corded Phone
What buttons do I press to reset 8410D phone?
You can not. It needs to be done from the command line at the admin console.
Dec 28, 2009 | Avaya Definity 8410D Corded Phone
HOW TO INSTALL AVAYA PHONE 8410d 1 line at home
First, buy an Avaya Definity system. Then learn to program the system. Then you will know.
That phone will not work without the control unit. The conrtol units cost a few thopusand dollars and about 1 month of training to install.
Dec 13, 2009 | Avaya Definity 8410D Corded Phone
How to set intercom
Hi
Phone functions are set on the pbx on the station form, not on the phone itself
check support.avaya.com for further info
Aug 07, 2009 | Avaya Definity 8410D Corded Phone
Lands Phones Logo
77 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
