Question about Refrigerators
Water freeze"s up on the bottom of refrigerator,at least once a year,how do i fix it
  • 3 Answers
If it is a sub zero with the freezer on the bottom you can have a insulation problem. The cold from the freezer can creep up into the fresh food section and freeze the drain tube. They sell an aftermarket drain heater that wires into the fan motor.
Posted on Apr 27, 2015
    Top Expert:
  • Refrigerators Master
  • 42,771 Answers
Clean out the drain in the back wall of the fridge. reset the thermostat setting to a warmer setting
Ge side by side refrigerator water dispenser doesn't work
There are a couple reasons why the water dispenser will not work and they are water freezing in the dispenser water tank or a defective=> WR57X10032 Water Inlet Valve
How to test this part is shown in a vedieo on the same page as the part. I will be here should you have questions, Thanks Sea Breeze
Feb 05, 2013 | GE Profile PSW26P Stainless Steel Side by...
The bottom part (vegtable bin) has been freezing and the water dispenser freezes. Refrig is 7 years old, never had this problem before.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 03, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
WATER POOLIN AND FREEZING AT ON FLOOR OF FREEZER. ICE MAKER NOT HOOKED UP
you have a blocked drain remove back freezer panel
at the bottom you will find a lot off ice remove it with hot water and clean drain hole the pop is the ice cracking
Apr 17, 2009 | Refrigerators
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frididaire side by side refrigerator- water freezing in bottom
Frozen or Plugged Defrost Drain
On Side By Side Refrigerator
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models the pan is accessible without removing the back panel and others are not.
Once you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster like this one: Turkey Baster http://www.repairclinic.com/SSPartDetail.aspx?PartID=428708&PPStack=1
To squirt hot water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
Jan 27, 2009 | Frigidaire FRS20ZSG
Top of the freezer will freeze but bottom want
Could be same as problem I just fixed.
Remove back panel inside freezer and
1. check fan operation
2. check for ice/water at bottom of the hidden section. There should be a drain hole, which may be blocked by ice. Fix by turning off and pouring boiling water in there until blockage is fixed
See http://www.fixya.com/support/t1507330-ice_collects_in_bottom_freezer
Dec 26, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice maker not making ice
1)First check you have a water line that is getting water to the ice maker.
2)Ice makers have a valve at the bottom that open and close when told by the ice maker replace that cheap fix.
3)The ice maker needs to be repaced.
(how far into the line will the water freezehow far into the line will the water freeze)
.The valve at the back opens and closes will not leave water in the line to freeze.
Dec 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer leaking on Ge Profile
The drain is frozen over and water cannot escape when it defrosts. You will need to remove the back panel inside the freezer and run some hot water down the drain until it has thawed. Hope this helps
Sep 24, 2008 | Refrigerators
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
